Mistake or Not?? input needed - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-15-2013, 07:47 PM Thread Starter
kachup's Avatar
Exclamation Mistake or Not?? input needed
Just Bought a 4 inch new Diamond eye Down pipe, I want to bolt it on to my flo pro dpf pipe delete. which is stock size, Will it bot on?
Should i cut my OEM downpipe to install the new Downpipe?
If so what should i notice, HP,EGT Lower, Fuel economy or more tq.
i appreciate the input
97 TT SUPRA
08 F250 MY DD
kachup is offline
post #2 of 5 Old 12-15-2013, 07:48 PM Thread Starter
kachup's Avatar
if you have a Diamond eye down pipe plz tell me your review.
97 TT SUPRA
08 F250 MY DD
kachup is offline
post #3 of 5 Old 12-15-2013, 09:56 PM
Clayton1985's Avatar
You'll have to cut it to get it out, unless you remove cab or other ****. That's why the new dp is 2 piece. I don't have flo pro soi can't comment on it.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #4 of 5 Old 12-16-2013, 10:28 AM
WoodBoy's Avatar
Yes it SHOULD bolt up and yes you will have to cut your stock out. If the bottom of the downpipe is a ball/socket type end just like the factory then it should fit.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 5 Old 12-17-2013, 05:54 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
yes you have to cut the downpipe. I can't remember if I have a Diamond Eye or FloPro DP, but they should be almost the same. If you look thru my build thread I have some pictures of the cut OEM downpipe. It is VERY restrictive.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
