Want to delete EGR/DPF but I don't want to add HP. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 76 Old 12-10-2013, 01:21 PM Thread Starter
Like the title states I just want to delete those two trouble makers and I don't want to add anymore pressure to the combustion chamber as my block isn't studded. I don't mind running a tune if it is a tune that will make the engine more reliable and durable.
What are my options? DPF-R? does it do a EGR delete also?
2009 F 250 Lariat 6.4 PSD
cterrebonne is offline
post #2 of 76 Old 12-10-2013, 02:07 PM
Yes, the Gearbox Z shuts off the DPF and EGR. You will need a new pipe (or at least a DPF delete pipe)and have to keep the sensors connected to close the circuit but they can be zip tied to your frame. I would highly recommend the going with the 4 plus model, it only adds 70 hp and the truck will run a little stronger. I have towed 10K with it with no problems, EGT didn't get higher than 1140.
jwbeav is offline
post #3 of 76 Old 12-10-2013, 02:08 PM
I wouldn't do the EGR delete unless you have a leaking EGR cooler. Just do the block off plates with the tune.
jwbeav is offline
post #4 of 76 Old 12-10-2013, 03:14 PM
I know it's been cover a million times. I just got a 6.4 with 238,900 miles on it. Completely stock. About to make a 3500 round trip vacation, interested in egr/dpf delete. However after all the searching. I haven't seen a good write up on what exactly to do....parts numbers, plates, pictures, pipe, tuner etc. it's a bit much until I can read a thorough write up. If someone would point me in the right direction I would appreciate it. I'd like to do this this weekend so I can start seeing the return on my money MPG-wise.
iowncars is offline
post #5 of 76 Old 12-10-2013, 03:17 PM
Quoted: 2 Post(s)
Evidently you've never seen the inside of a 6.4 manifold after running an EGR for numerous miles.......It looks like roofing tar mixed with charcoal.
These deposits going back into your engine are KILLERS!!!!!!
Truckmaniac is offline
post #6 of 76 Old 12-10-2013, 03:25 PM
Quoted: 45 Post(s)
The first thing you need is the proper (race) tuner that supports deleting the EGR. Next would be the exhaust: a DPF delete pipe at the minimum. Next would be an EGR delete kit. This is the starting point. After this you can also add an intake and other goodies. If you are going to do this do it right the first time, so spend more to get more. Go with a Spartan or H&S Mini Maxx (race) tuner.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #7 of 76 Old 12-10-2013, 03:33 PM Thread Starter
I understand what you are saying from a performance stand point, but my goal is to make the engine as reliable as possible. That's the main reason why I want to do a EGR delete. I don't need the tops of my valve train and intake being coating with roofing tar. Now I know that running a water/alky injection will clean that right up but that might be an update down the road because from what I read it makes everything run better and more reliable.
Is the Mini Maxx or the Spartan worth the extra coin even though I want a stock HP tune?
post #8 of 76 Old 12-10-2013, 03:36 PM
Don't the block off plates prevent the exhaust from going back into the manifold? Also, the Gearbox Z tuner closes the EGR valve so there isn't any exhaust running through the coolers...at least that is my understanding.
I agree with the recommendation on tuners and would throw in one other, SCT 3015r. It shuts off the EGR, deletes the DPF and you can get custom tunes from Gearhead, IDP, etc. They are becoming very hard to find.
jwbeav is offline
post #9 of 76 Old 12-10-2013, 03:45 PM
Quoted: 45 Post(s)
You CANNOT delete the EGR and/or DPF without doing what I said previously. It costs the same to run those tuners on a stock tune or +300 so what it really comes down to getting over your fear of power.
post #10 of 76 Old 12-10-2013, 03:49 PM
WoodBoy's Avatar
Someone has already recommended the DPF-R 4.0 to delete the stuff, it doesn't have to be a Spartan or H&S to delete the dpf and egr bud
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
