BOOST??????
DOES THE DD SHOW WHAT THE BOOST IS? IF SO HOW DO I GET IT TO SHOW? THANKS
I believe its under the intake pressure..........
You have to make sure you update it with the latest firmware for it to read boost right, and if you do that along with the update config file from Spartan the gauges will be all set up for you, including boost.
where do i go to update it thanks
Boost is MGP manifold gauge pressure.
Do you have the DashDaq Updater software? There is a button on it that says check internet for updates........we can now use that to download the latest firmeware
I would hold off on the update for now....theres an issue with the latest firmware and returning your truck to stock....they are working on it but personally I would just keep the firmware that Spartan had us download the last time, and not use the check web for updates.
yes but some poeple are having problems with there stock file loading back in(including me) cuz of this new firmware
So yes....PERSONALLY I would hold off on the latest update. |
