DPF-R with edge tuner - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-09-2013, 08:49 AM Thread Starter
Hello, I am new to the 6.4 world and I have a couple questions. I obtained a edge juice with attitude tuner that does not support dpf delete. I like it however so I can monitor by levels and what not. I am looking in getting a DPF-R 4.0+ to enable me to delete my cat and dpf filter. Is it possible that I can still use my edge with the dpf-r installed? Thank you in advance.
http://www.gearboxz.com/shop/product...lus-progammer/
Edge Products| Product
cole_slaww is offline
post #2 of 3 Old 12-09-2013, 10:19 AM
WoodBoy's Avatar
It should work fine I seen somewhere that Gearboxz said that their product worked well with the edge juice but not the edge cts programmer. Make sure you get the dpf-r that doesn't add 70hp if you are going to run them together
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 3 Old 12-09-2013, 11:44 AM
Or you can get the + model and just turn it to the "standard" tune which is DPF/EGR delete without the 70 hp bump.
The DPFR only stacks with tuners that don't adjust your PCM, I believe the Edge Juice is one of those but you may want to verify with Gearbox Z. I went through this exercise with the DPFR and an SCT only to find out the two don't work together with custom tunes.
jwbeav is offline
