DPF/DOC Delete - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-06-2013, 07:20 AM Thread Starter
Blade843's Avatar
DPF/DOC Delete
So I'm getting ready to do a DPF/DOC delete and i am curious about a few things before I start. What all sensors am I going to run into? Has anyone had any codes pop up after the have completed it? I'm new to this and want to make sure i have everything covered when i do it so im not running into problems. The kit im pretty sure im going to get is all bolt up so i should be good there. Just really curious about the sensors.
Any suggestions and comments will be greatly appriciated.
Thanks,
Blade843 is offline
post #2 of 14 Old 12-06-2013, 07:21 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
the kit/tuner part should take care of the codes...have a link to the kit? the 6.4 guru's can help tell you more.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 14 Old 12-06-2013, 07:29 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
make sure that you load up your tune ,after you remove the 3 sensors from the exhaust, before you start the truck,,, do not start the truck without the sensors and without the tune.......if your truck does throw a code, you should be able to clear it with the tuner, but as long as its tuned prior to starting it you will be fine..... super simple once you get into it...
08 F350 MINI MAXX,5"FLO-PRO DPF DELETE, AFE INTAKE,HID'S,BFG A/T'S ON 20" BMF NOVAKANES,TIMBREMS,BLACKED OUT BUMPERS GRILL,STEPS RACING STRIPES,PAINTED HEADLIGHTS ,FABTECH LEVELD,RCX DUAL STABILISERS
INJEKTER1 is offline
post #4 of 14 Old 12-06-2013, 07:33 AM Thread Starter
Blade843's Avatar
I seen the gas tempeture sensor but i beleive thats on the DPF. What other sensors are on it the pipes? I have a SCT tuner
Blade843 is offline
post #5 of 14 Old 12-06-2013, 10:25 AM
INJEKTER1's Avatar
Quoted: 4 Post(s)
ONE IN THE CAT and i think one before that
post #6 of 14 Old 12-06-2013, 11:15 AM
WoodBoy's Avatar
There are three temp sensors and a pressure sensor. Unplug them and drop the exhaust out from under the truck then use a good wrench and penetrating lubricant to remove them out from the exhaust. Once you do this you can either plug them in and tie them out of the way or if your new exhaust has bungs you can thread them in and then plug them in.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 14 Old 12-06-2013, 11:53 AM Thread Starter
Blade843's Avatar
so do i need to plug them in or no? i seen pipes that have no bungs. Im guessing its better to have them in right?
Blade843 is offline
post #8 of 14 Old 12-06-2013, 12:04 PM
WoodBoy's Avatar
They do have to be plugged in for SCT. Its up to you whether you want to tie them up to the frame or put them in the aftermarket exhaust.
WoodBoy is offline
post #9 of 14 Old 12-06-2013, 12:22 PM
I have an H&S so not sure if it is any different, but I unplugged 3 total. Didn't bother taking them out of the exhaust. Just tied the sensors up. No codes on my truck.
Again, not sure if the H&S is different though...
seafordguy is offline
post #10 of 14 Old 12-06-2013, 12:27 PM
RADIOFLYER's Avatar
H&S you don't have the have them plugged in. Mine arent. Do the removal first, don't start the truck, tune it, star it, and your gtg. FYI, H&S will turn off the egr.
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
RADIOFLYER is offline
