Egr delete and t-stats R&R - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-03-2013, 07:33 PM Thread Starter
okay so i decided to take some pictures of me doing an egr delete and replacing the t-stats and updating the rad hoses
Here is when i first started
Degas and battery removed
connection between coolers for exhaust i decided not to cut the elbow i just removed it maybe a little bit more time but not bad
I also did not remove the drives side tire or inner finder just disconnected the steering shaft and went at it that way
Here is the vertical cooler removed
08 250 ccsb H&S Mini Max, AEF stage 2,flo pro egr delete. W/ intake elbow, 4in TB Diamond Eye exhaust, and arp studs.
bigtrucks85 is offline
post #2 of 4 Old 12-03-2013, 07:53 PM Thread Starter
horizontal cooler
horizontal cooler gone
this is the inside of the intake and the main reason to do an egr delete
and if you look close you can see the t-stat housing behind the vertical egr cooler which is the other reason i did an egr delete
post #3 of 4 Old 12-03-2013, 07:57 PM Thread Starter
Here is the intake elbow installed
post #4 of 4 Old 12-04-2013, 06:25 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Very nice. Good job!
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
