Need some DPF info - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-02-2013, 07:16 PM Thread Starter
Acef250's Avatar
Need some DPF info
This may have a thread already but I couldn't find it so I am making a new thread. Ive got a 08 F 250 and I am saving to get enough cash to do the DPF and EGR delete with a off road tune. Right now I just want to get the pipe to swap out and remove the DPF and the CAT, my question what would the repercussions if I were to just delete those two items without using a tune. Would there be any damage to my computer at all and will the truck still be drivable. I ask because I do not have the cash to get a $800-$1600 dollars for a tuner.
Thanks , Ace
Acef250 is offline
post #2 of 6 Old 12-02-2013, 07:58 PM
Lipka101's Avatar
Quoted: 61 Post(s)
You need a tune. No damage to computer but truck won't run properly and try to regen. And cause engine damage. Oh and it will smoke a **** ton. I have a dpf-r 4.0 for 250 shipped. It will tune the truck to run without dpf but adds no power.
Lipka101 is offline
post #3 of 6 Old 12-03-2013, 07:07 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As stated you need a tuner to delete the dpf. It wont run without it.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 6 Old 12-04-2013, 08:16 AM Thread Starter
Acef250's Avatar
Thanks for the info. That's exactly what it was looking for.
Acef250 is offline
post #5 of 6 Old 12-05-2013, 05:49 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
If you do you will get 1 start without the dpf on it. Once you shut it off it won't start again till you clear all codes. And like they said you can't do it that easy or tuners wouldn't be so expensive and no one would have a dpf on their truck.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 6 Old 12-05-2013, 07:29 AM
I hate to be the one who tells you, but you are not getting a tuner for $800 - $100 unless it is used. However, I still suggest, you delete and tune, you will love it.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
