How can you tell if a truck has tune? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-02-2013, 11:20 AM Thread Starter
kilr4d's Avatar
Question How can you tell if a truck has tune?
Couple of questions. Bought a used truck (repo with no keys) and it won't crank.
Towed it over to the Ford dealer and got 2 PATS keys cut and programmed. Flashing PATS light has gone away. All wiring appears intact. Truck will not crank. TCM and PCM both have power. If you jump the starter, the truck will crank, start, run and drive, everything works.
The complete exhaust from the downpipe back is missing, including sensors. The Ford dealer tells me that it there is a "crank inhibit" if the backpressure/EGT sensors are out of range. Is this correct?
Here are the 3 active codes currently in the ECM:
P0546 Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P2033 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
P2455 Diesel Particulate Filter Pressure Sensor A Circuit High
So, will those codes + no exhaust sensors plugged in inhibit start/crank?
Also, is there any way possible to tell if it's got a tune? I don't want to buy a delete exhaust if it's stock and I don't want to buy a stock exhaust if it's tuned.
Thanks for any help/direction you guys can offer.
kilr4d is offline
post #2 of 8 Old 12-02-2013, 12:53 PM
matted2thefloor's Avatar
The 6.4s will go into a default 1 hour "no crank" when 1 or more of the EGT sensors is unplugged. I effed up when installing my exhaust and tried to move the truck with them undone, it cranked to get me moved out and back in the shop, but when I shut it down and attempted to restart it...no dice. It went into the 1 hour "no crank" lock out...
I later read about that situation in some Ford literature...but can't recall where!
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #3 of 8 Old 12-05-2013, 08:54 PM
Capt dong's Avatar
Quoted: 5 Post(s)
hs tunes dont need sensors so you can rule that out.
either or both sct or spartan need them plugged in.
08 F250 KR
08 F250 XL
Capt dong is offline
post #4 of 8 Old 12-06-2013, 05:25 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Spartan doesn't need sensors either. Sct and dpf-r do need them. Based on them codes it looks like the truck is still stock. Buy an h&s race tuner used from the forums, make sure it is unlocked. Tune the truck and get ya an exhaust. It will be the cheapest way especially if you got wiring missing too. The owner prolly had it deleted and ripped his exhaust off and returned it to stock and let it get repo'd. Check to see if it has egr delete also because if it does you can't go back to stock exhaust with an egr delete or else you will have more codes.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 8 Old 12-08-2013, 08:05 AM
Powerstroke Techie
Have the dealer print you the IDS Log (Technician View) when they identify the truck and I can tell you from that what strategy is loaded.
My guess would be since the exhaust is missing, the guy who owned the truck before took the exhaust off and returned it to stock before they repossessed it. A repo isn't a surprise lol.
The exhaust missing will indeed cause the no-crank. Read my post in one of these sections called "Announcement - EGT13"
Since you are somewhat nearby, I can come look at it for you, and get a strategy loaded for you so it's at least driveable. Let me know via PM or text, I will PM you my number.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #6 of 8 Old 12-09-2013, 12:07 PM
travisH3's Avatar
Quoted: 2 Post(s)
also if you get an H&S no need to worry about what tune is on it. h&s doesnt save the stock file, they are programmed into the tuner so if you buy an H&S just download tune with dpf delete and away you go, if you ever return it to stock it will put a new stock file back on the truck so no more guessing
T-rav
2010 F350 6.4-
travisH3 is offline
post #7 of 8 Old 12-10-2013, 09:57 AM Thread Starter
kilr4d's Avatar
Sent you a pm.
Thanks!
kilr4d is offline
post #8 of 8 Old 12-10-2013, 09:32 PM
B585Ford's Avatar
Good point. I had forgotten that.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
