Mini Maxx Pyro Reading wacked out - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-30-2013, 07:11 AM Thread Starter
Hey guys, Ive got an 08 6.4 with a H&S mini running the 250 tune. Last night I was driving home and I noticed my truck defueling erratically. Then noticed my pyro was reading out about 1500-1700 degrees, so I immediately pulled over. At idle it was reading about 900-1000. I made it back to the house, and while doing so I noticed then when you got into the throttle a bit, the pyro would quickly read out normal temps while my foot was in it (500-700), but then went right back to 1500 or so when i let out of it. The truck runs perfectly normal, and my coolant temp never left 190. To me it sounds like my EGT sensor took a dump, but at the same time im nervous as all hell to drive it like that. Has anyone heard of anything like this happening? Any insight would be great,
Thanks! sorry about the long post...
2008 F-250 SD Job 1
H&S Mini Maxx 250 tune
5" Diamond Eye DP Back Straight Pipe
AFe Air Filter
wattersfarms is offline
post #2 of 4 Old 11-30-2013, 07:32 AM
Quoted: 48 Post(s)
the temperature sensor is probably starting to short out
drunk on diesel is offline
post #3 of 4 Old 12-01-2013, 08:25 PM
B585Ford's Avatar
I agree with Drunk On Diesel unless when you getting those high readings was it smoking (black) real bad. If you truley had EGTs that high, you would have to be dumping a lot of fuel and since you weren't accelerating, I would say it is very unlikely those EGTs were correct.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 4 Old 12-02-2013, 06:50 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Yup you need a new egt probe most likely. Mine was doing weird stuff not long ago and now it seems to be working again.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
