Limiting boot? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-25-2013, 07:09 PM Thread Starter
Limiting boost
Does the computer restricting max boost?
2010 6.4 Dually.
I have K&N air filter kit (not the drop in), aFe inter cooler, Mishimoto Cold-Side Intercooler Pipe, aFe DPF delete, aFE 5" DPF back exhaust, aFe 4" down pipe, EGR disabled/blocked.
Also running a custom tune that is basically a tow tune.
Watching my CTS edge I notice my max boost is 32 no matter what.
So I'm wondering is the computer forcing max boost at 32 or is that the max the stock turbos can make?
It think even in stock my max boost was 32.
Thinking of switching my low side turbo to 71mm but wondering if there's something in the code that I need to talk to my tuner developer to solve this.
She will try but I have to pay for the time if she can get it to work or not and prefer to ask before spending a couple hundred dollars.
Thanks.
Last edited by GSchretter; 11-28-2013 at 05:50 AM. Reason: Turbo bumped to 32 instead of 31
GSchretter is offline
post #2 of 9 Old 11-27-2013, 01:47 PM
Capt dong's Avatar
Quoted: 5 Post(s)
The stock turbos can make over 40 psi. I think I've seen over 47 psi. I have my defuel levels on 35 psi on my Mini Max for everyday driving. It's possible that Edge tuning is conservative to prevent engine damage.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 9 Old 11-27-2013, 08:52 PM
srjd's Avatar
Quoted: 2 Post(s)
What he said its probably your edge tuning for that tune. Stock truck can make 40
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 9 Old 11-27-2013, 09:54 PM
Clayton1985's Avatar
I think its 41 to be exact
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #5 of 9 Old 11-28-2013, 05:43 AM
Quoted: 45 Post(s)
The max I remember seeing on the Mini Maxx is 42.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #6 of 9 Old 11-28-2013, 05:48 AM Thread Starter
I'm using a custom tune with my 3015 SCT that is rated a tow (1).
Will try the next level (2 of 4) to see if my boost increases a little.
I only use the CTS Edge for monitoring and for the backup camera
Thanks.
post #7 of 9 Old 11-28-2013, 06:57 AM
WoodBoy's Avatar
Fuel and timing is going to determine your boost so your tow tune isa very small tow tune. It should go up with tunes. Load your largest tune and see what Max boost is with tc locked
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 9 Old 12-01-2013, 08:09 PM
B585Ford's Avatar
I agree with everyone else. Your tune is limiting your boost.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #9 of 9 Old 12-02-2013, 06:35 AM Thread Starter
Found a few issues.
1. Forgot to put the air sensor back in the CAT after removing DPF
2. New aFe downpipe to exhaust was loose.
Once corrected I hit 38 PSI and for now that's good enough but you guys are correct tune stops at 40PSI.
Thanks!
