New to me 6.4 questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-24-2013, 09:25 AM Thread Starter
Post New to me 6.4 questions
Hey guys. I picked up a 6.4 about 4 months ago and I love it. The truck still under warranty I can't go to the dealership for these answers so here I am.
I've had it tuned for about 8k miles with the Spartan 275 tune, the truck is coming up on 35k miles.
How often should I change my oil?
How often should I change my fuel filters?
When should I tranny flush?
I use my truck as a weekend warrior, next to no pulling at all. Is an EGR delete something I should consider? If so, how does it benefit the truck?
Any other advice for a newbie, feel free to chime in!
Thanks in advance.
2010 F350 CC/SB, Spartan, 4'' MBRP, S&B Intake
bigtimef350 is offline
post #2 of 7 Old 11-24-2013, 09:52 AM
Echo's Avatar
Oil around 5k
Fuel filters around 10k
Trans aprox 50k
As far as the erg delete it doesn't really do anything performance wise it is just for insurance in case one of the coolers fail
Echo is offline
The Following User Says Thank You to Echo For This Useful Post:
bigtimef350 (11-24-2013)
post #3 of 7 Old 11-26-2013, 12:15 PM
Capt dong's Avatar
Quoted: 5 Post(s)
If you are deleted you can go up to 8k miles. I have some Blackstone tests and they came out great.
As mentioned around 10-15k miles. Drain your water fuel separator once a month.
I think the transmission fluid service interval is 60k miles with Mercon SP or LV.
You don't have to delete the EGR especially if your state requires it on your vehicle. It's just a safety precaution from it rupturing and spilling back into your block. I think the Spartan tuner turns it off.
08 F250 KR
08 F250 XL
Capt dong is offline
post #4 of 7 Old 11-26-2013, 12:50 PM
egr delete is a great idea. if one of the coolers cracks (which they are prone to) it can leak coolant into the cylinder and you will bend a rod or hydrolock the engine.
SOOTIE is offline
post #5 of 7 Old 12-01-2013, 07:27 PM
B585Ford's Avatar
If you are still under warranty and hoping to keep it that way, you should probably hold off on deleting the EGR. I agree deleting the EGR is a good idea, but it is one more thing you will have to put back on before you take it for warranty work. Also, you might want to re-route your CCV.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 7 Old 12-03-2013, 02:00 PM
RADIOFLYER's Avatar
Your truck will be happier with the egr race plate in there. Won't be as smokey and will spool much better. I highly recommend replacing the factory cold side charge pipe to a upgraded 3" with a race mouth piece (which will remove all of the egr components). then just throw in the race lates on top of the turbo and in the coolant ports.
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
RADIOFLYER is offline
post #7 of 7 Old 12-07-2013, 06:46 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
You can go much further on oil. I did 10k this change. I've been slowly stepping mine up under the directive of Blackstone labs.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
