EGR delete - with a tune - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-21-2013, 07:31 AM Thread Starter
I have an SCT Livewire and was wondering if there was a way to delete the EGR using a tune or does the delete require an equipment change?
2015 F250 Lariat SD FX4
6" Rough Country Lift
20" XD Series Wheels
37" Nitto Trail Grapler M/T
Stock
2008 F250 Super Duty 4X4
6" Pro Comp Lift
Pro Comp 6001 Wheels
Nitto 37" Terra Graplers
4" dpf/cat delete w/MBRP
SCT Tuner - Performance Tune
bsudkamp is offline
post #2 of 4 Old 11-21-2013, 11:27 AM
WoodBoy's Avatar
You cant delete the egr without actually "deleting it" by removing it from the vehicle. You can turn it off with the tune but the components are still there, there is still coolant flowing through the coolers that could potentially crack. When you download a tune it should ask you if you have removed the egr components and you just select yes. It turns it off.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 4 Old 11-21-2013, 12:48 PM Thread Starter
Thought that was the case. Thanks for helping me out.
Stock
6" Pro Comp Lift
bsudkamp is offline
post #4 of 4 Old 11-30-2013, 09:27 PM
B585Ford's Avatar
If you have the funds and don't have to worry about emissions testing, I would delete it.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
