Help with a little rebuild - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-20-2013, 06:52 AM Thread Starter
I'm in the process of changing hpfp, rails, and injectors. Looking at the sweet push rods/rockers,are they really an issue when running bigger Spartan tunes? Also I was thinking about getting a airdogII ,what is really needed , 100,150,165 . .... well I have it apart I want to do a few upgrades without going broke. With that being said heads are staying on, I'll do the studs and gaskets another time. The truck is a daily driver I usually run the 275 then the 210 tow for towing the camper. I had the 310 on when the pump came apart.... I just want it to be reliable when I play like my duramax was. JK never ran more then a 100hp on the dmax .
ID:	201346   Click image for larger version
dialedin is offline
post #2 of 2 Old 11-20-2013, 06:55 AM Thread Starter
Oh yeah 09 6.4 any suggestions / info appreciated. Also replace all injector feed lines correct?
dialedin is offline
