Titan Tank - Ford Powerstroke Diesel Forum
Old 08-14-2008, 03:13 PM
Titan Tank
Just got the 52 gallon Titan Tank installed in my 250 cc. Does anybody know if the mileage to empty will still work? The Ford guys that installed it for me were not sure if it would but my service rep said if it didn't they would contact Ford and try to get a fix.
Old 08-14-2008, 08:34 PM
bubbasc - This should help....
Titan 62 gallon tank installed - Diesel Forum - The Diesel Stop.com
Old 08-14-2008, 08:42 PM
i disconnected the battery and turned the lights on for a few hours to reset the computer after I had run two tanks and it was way off....after that it was within a few miles of being correct
Old 08-20-2008, 07:35 PM
did you have the recall fuel tank bracket already installed and did it interfere with placement of the new tank?
how low does the tank hang below the frame rail?
thanks
Old 08-21-2008, 08:10 PM
no recall performed on mine...its just fine.....it hangs down just as much as stock....
Old 08-22-2008, 06:42 AM
from a picture that i saw it looked like there may be some ground clearance issues created. the transfer tank brand looks like it hangs down about 4 inches below the rail
Old 08-22-2008, 08:55 AM
Let me see if I have a photo of it installed....
Old 08-22-2008, 09:29 AM
thanks again
Old 08-27-2008, 05:48 PM
Yes the recall bracket is in the way but you just pull it off and throw it away. The tank bottom is at the sem level as the bottom of the rear axle. If you want to talk about clearance issue if the tank hits anything then the rear axle is going to get it as well. The main reason for going with Titan is the tank is made of the same material as the stock tank. I do not want a metal tank when I spend my winters in the north.
