Adding stand alone trans cooler, Anyone done this? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-17-2013, 10:16 AM Thread Starter
rabbitCTSV's Avatar
Im in the process of signing the final paperwork on a big RV trailer, goosneck , my question is about the trans, I have never had any problems with mine but the converter, i replaced with a billet converter last year, I have 175k on the clock and looking to keep it going longer, I have added a external trans filter , i was looking how easy it would be to add a massive cooler to it and bypass my cooler built into the radiator. this way it will help keep all that cool and get my trans lower on temp by running a stand alone,
1. anyone see any reason why i can't or should not do that?
2. is the stock trans fluid pump good enough to do this? if not do i need at add another one in line?
3. what is the lowest recommended temp to run the trans at.
4. what is the max temp?
thanks everyone.
King ranch with the 1st 2011 king ranch console mod
20 king ranch wheels with 12.5/ 35/ 20 AT
Nav upgrade with ProBox
H&S mini maxx w/custom dash mount
external transmission filter.
external added oil filter
external coolant filter
5" diamond eye exhaust with 4" DP
sinister EGR delete with elbow
IC pipe 3" with no restriction / Cleaned intercooler
Raptor Ridged 24" light bar in middle of bumper
Raptor Ridged led fog lights
title in hand from day 1
rabbitCTSV is offline
post #2 of 6 Old 11-18-2013, 02:39 PM
That's a good question I am interested as well , I tow a 40 ft toy hauler
08 f-350xlt 6.4 , spartan tuned
3.55 gears are in the bin replaced with 4.3. 35/12.5/20 toyo's
40 foot fuzion 362 toyhauler 16k fully loaded
1997 7.3
bts trans. wop injectors, afe intake, straight exhaust
4" lift 6pos ts chip.
djen223 is offline
post #3 of 6 Old 11-18-2013, 02:45 PM Thread Starter
rabbitCTSV's Avatar
well when I get back from overseas I'm going to order a big cooler and temp controlled switch , I'm going to put it threw its paces and see how it turned out, ill start by towing my trailer for 30 min down the highway log temps, then do the swap and log temps, if I see a decrease in temp then ill know it works then ill dial in the temp by using a temp switch hooked to a fan, for the first solo run fan will be on all the time,
post #4 of 6 Old 11-18-2013, 02:50 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive always threatened to get one of those fancy tranny fans with the fins on them. But after a long tow this summer I found the tranny temps to never be a issue.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 11-21-2013, 08:07 AM
SANDDEMON08's Avatar
thanks everyone.
Yep did this awhile back here is the write up, hope it helps
HEAVY DUTY TRANS COOLER INSTALL
611HP 1205 TQ
08 F350 CC FX4, 6.4 PSD,PMF 4.5" LIFT WITH TRACTION BARS,3.73 REAR,NAV,DASH DAQ,VOLANT INTAKE,SPEARCO INTERCOOLER,STAGE III WATER/METH,67 GAL TITAN TANK,EGR DELETE,ARP HEAD STUDS,72MM LP BILLET TURBO,RCD CONVERTER,FS-2500 BYPASS FILTER, AIR DOG II FUEL PUMP,CUSTOM CCV,MAG-HYTEC TRANS PAN AND DIFF COVER, CUSTOM HD TRANS COOLER, SEIC MOD,AMP STEPS
SANDDEMON08 is offline
post #6 of 6 Old 11-21-2013, 09:44 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 63 Post(s)
the transmission has an internal thermostatically controlled valve that will only sip fluid exterior to it until an operating temperature of 165* is achieved... at what point it is fully open.. it will flutter in attempts to maintain that temperature...
this chart is good info as to what you should expect when discussing temperature vs. life:
adding an exterior cooling plate adds both volume and exchange surface (duh), but it also will add years of life to your transmission... Heat is the enemy.. that said, too cool is an enemy too, not to parts or clutch surfaces, but to quality of shifts.. it will shift hard... shifting hard isn't bad for the transmission, either, but it is bad to folks who think there is something wrong and break it open to find out what... idiots working inside a piece of machinery above their station are enemy #1 to a transmissions longevity.
drewactual is offline
