Spartan DD Boost
I know it was stated on here a few weeks ago, but I cant find it. I am trying to figure out how to monitor boost on my DashdDaq. I have the latest revision and am monitoring everything else I want to, but can't find the boost. Any help is greatly appreciated. Thanks!
I do not know if their is a corrected value which shows just the addition to the atmospheric above the 14.70 PSI.....? MATT?? Mike |
THeres corrected stuff...new firmware, and config files....all posted over at his forum for easy download.
EGT, boost, everything reads right. |
I found it
MGP = Manifold Gauge Pressure (boost)
I found it at Spartan't site. Thanks guys |
Boost seems to be hung on 15 on the DashDaq. Is anyone seeing correct boost numbers on the DashDaq. I am using the MGP to monitor it. I adjusted the ranges from 0 to 50 and it always reads 15. Thanks for any help!
try unplugging it and plugging it back in, I have had the EGT hang up and not read like that.
Thanks
Thanks Oil. That did it!
Mine did the same thing , I noticed it happened when I left the dashdaq on while I shut the truck off for a while and got back into the truck to turn the truck back on with the monitor still lit. If you get into your truck and notice you forgot to turn the dashdaq off when you left it, just shut it off and then start the truck, then turn the dashdaq back on and it should work fine.
