fuel - Ford Powerstroke Diesel Forum
Old 08-11-2008, 04:09 PM
fuel
I was wondering with the dpf delete can you run red fuel in the 6.4 ford? If anyone has does it run the same as the regular diesel meaning economy and hp?Its .40$ cents cheaper.
Old 08-11-2008, 04:20 PM
Almostdunfukinwidit
Most likely you can run it with the DPF delete. But I would not recommend it. The several thousand dollar fine you would pay when and if you got dipped is not worth it
Old 08-11-2008, 05:31 PM
I live in idaho where its mainly farmers
Old 08-11-2008, 05:33 PM
Almostdunfukinwidit
Thats the biggest reason i wouldnt do it. State patrol and DOT are more apt to dip your tanks in that kind of area
Old 08-11-2008, 05:46 PM
Yes it will run fine with or without the filter
Old 08-11-2008, 05:50 PM
Almostdunfukinwidit
However red fuel with the filter intact WILL void your warranty
Old 08-11-2008, 05:59 PM
There is no difference between regular diesel, and red diesel. The only difference is color and taxes.
Old 08-11-2008, 06:00 PM
Almostdunfukinwidit
That is exactly right. however red will void the warranty on the 6.4
Old 08-11-2008, 06:01 PM
Red will void the warrenty on any diesel.
Old 08-11-2008, 06:03 PM
Thats what I was gonna say ^
