Bullet-proofing my 6.4 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-13-2013, 09:47 AM Thread Starter
andrewpredz's Avatar
I am about to purchase a 2008 F350 CC/SB SRW with 59,000 miles on it. Once i buy it i will immediately do some aftermarket work to it. Now i know there are a billion threads, links, discussions about this but i did my research and narrowed it down to what i need now and what i can hold off on.
NOTE: The truck already has a DPF delete, turbo back exhaust and a Spartan Phalanx w/ DashDaq
So here is what I'm going to buy
1) Airdog 150 Fuel Air Separator with the PPE Dual Relay
2) Sinister Diesel EGR delete with intake elbow
3) Sinister Coolant Filter System
I just need some feedback if I'm going in the right direction here before i drop a grand. I was also thinking down the road to do an oil cooler but i think i will hold off a bit. I figured i couldn't go wrong with this setup besides having to remember to change a million filters
-- Andrew -- Connecticut --
2008 Ford F-350 Lariat CC/SB SRW
afe intake/mbrp 5" turbo back/minimaxx
WHELEN
andrewpredz is offline
post #2 of 5 Old 11-13-2013, 10:18 AM
bentstroke_02's Avatar
Well looks like you are going in the right direction. Id also do a coolant flush and replace with cat elc
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #3 of 5 Old 11-13-2013, 12:15 PM Thread Starter
Thanks for your help. Ill make sure i write that down. I called a local diesel shop and they told me i should hold off on the Airdog and to replace the head studs instead. And on top of that he told me i definitely need a wastegate with my EGR delete because with a tuner there will be too much back pressure. The wastegate/headstuds sound pricey to me. Anybody have any advice?
WHELEN
post #4 of 5 Old 11-13-2013, 12:30 PM Thread Starter
Update: After a little research I know i can live without the wastegate for now. I won't be running a very large tune on the truck. Im looking to keep it around for a while so if anyone could let me know what has/hasnt worked for you…etc I would greatly appreciate it
WHELEN
post #5 of 5 Old 11-14-2013, 11:13 AM
Supporting Vendor
Quoted: 37 Post(s)
As I'm sure you are aware, these trucks are prone to leaking radiators. If you haven't seen, we offer an all-aluminum radiator, that is a direct-fit into the 6.4! This radiator comes with a lifetime warranty as well, so you won't have to worry about buy another one! This is definitely one way to bullet proof your truck.
Thanks,
Tyler
Mishimoto is offline
