SCT iTSX Tuner- feedback anyone? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-09-2013, 05:52 PM Thread Starter
Quoted: 2 Post(s)
Thanks in advance for your input!
I'm looking for an economical option to do a cat/dpf delete on my 6.4. Not looking for crazy power and probably will do just tuner, delete pipe, and cai.
Was considering the SCT 3015OR but the iTSX provides some monitoring for just a few more bucks. Has anyone run the SCT iTSX tuner and how well did it work?
Heavychevss is offline
post #2 of 12 Old 11-10-2013, 10:28 AM
WoodBoy's Avatar
I've never ran one and I will give you the reason why I and many others haven't. The unit looks nicer than the Livewire for sure but the programming on 6.4s and other newer model trucks are very sensitive and the lack of hard wire during programming has steered many of people away from the iTSX. A simple miscommunication during programming can cause a bunch of problems
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 12 Old 11-11-2013, 08:38 AM
Franchi's Avatar
Feedback Score: 22 reviews
ITSX wont work on a dpf deleted 6.4.
Only options, for a SCT tuner for dpf deleted 6.4 is either a 3015 R model or Livewire 9625 OR. Neither of which you can buy new anymore, have to find one used online.
Franchi is offline
post #4 of 12 Old 11-11-2013, 09:49 AM
WoodBoy's Avatar
There were some TSX Extreme Offroad produced
WoodBoy is offline
post #5 of 12 Old 11-12-2013, 01:45 PM
Franchi's Avatar
That's true but the iTSX is different then the tsx. The ITSX 4015 is the android/iPhone wireless tuner. TSX was a different model they only made for a year or so prior
Never made sense to me for the closeness in the name between the two.
Sent from AutoGuide.com App
Franchi is offline
post #6 of 12 Old 11-15-2013, 08:59 AM
drilldog's Avatar
I have a wireless TSX and a 3015R. I never had a problem with the TSX losing communication with the truck during a download. I am currently using the 3015R because I have custom tunes in it. Does anyone know if I can plug in the TSX and use it for the EGT guage or will it cause a problem?
2009 F-250 CCSB
PIAA/HID
Buckstop Bumper
Warn 1200
SCT tuner w/ RCD tunes
DPF/CAT del
AFE stage II
drilldog is offline
post #7 of 12 Old 11-15-2013, 09:37 AM
WoodBoy's Avatar
You should be fine as long as you don't download a tune from it
WoodBoy is offline
post #8 of 12 Old 11-15-2013, 09:46 AM
drilldog's Avatar
Thank you WoodBoy. I will definitely try it. Might as well use it instead of it just sitting around. Kind of an expensive guage though. I am sure I have probably read it on here before but which tune do you like better, Innovative or Gearhead? I am currently running a RCD tune but have room for 1 more. I was thinking about Innovative's Extreme Street.
2009 F-250 CCSB
PIAA/HID
Buckstop Bumper
Warn 1200
DPF/CAT del
AFE stage II
drilldog is offline
post #9 of 12 Old 11-15-2013, 09:49 AM
WoodBoy's Avatar
Its hard to say. They are both great tunes. I am currently running my IDP extreme street but I switch up often between IDP and Gearhead. You will be satisfied with either
WoodBoy is offline
post #10 of 12 Old 11-15-2013, 09:55 AM
drilldog's Avatar
What tuner do you have?
2009 F-250 CCSB
PIAA/HID
Buckstop Bumper
Warn 1200
DPF/CAT del
AFE stage II
drilldog is offline
