Exhaust - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-08-2013, 04:31 AM Thread Starter
Blade843's Avatar
Exhaust
Im planning on getting exhaust put on my 08 F250 6.4 Powerstroke, what would be the best idea. Some say dualed out with smaller pipe some say 6 inch all the way back or stacks. Any suggestions or what would be the best?
Blade843 is offline
post #2 of 6 Old 11-08-2013, 05:22 AM
WoodBoy's Avatar
Ive never seen a 6" exhaust but anyways. There is really no difference after 4" besides sound and looks.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 6 Old 11-12-2013, 06:49 AM
DieselManor's Avatar
To be honest, duals are just for looks. I have 4" duals. There's no performance difference from them vs 4" single, I had that too. Anything larger than 4" isn't necessary for most street trucks. 5" or even 6" stackes aren't going to give you any perf. gain. Remember, your turbo outlet is less than 4", so you can hook up a sewer pipe to it, and it won't make any difference.
Here's a link to all our systems for the 6.4L
Diesel Exhaust Systems for 2008-2010 Ford 6.4L Powerstroke at DieselManor
And if you're looking for stacks..
Exhaust Stacks and Accessories at DieselManor
David Murphy
DieselManor is offline
post #4 of 6 Old 11-12-2013, 07:44 PM
You won't notice a bit of difference in performance or sound if you replace the exhaust from the DPF back. To get Hp gains you need to get rid of the DPF, which requires a tuner as well. You will notice a huge Hp change with this upgrade. I ran the stock exhaust behind the DPF delete, and then ran an aftermarket exhaust, I didn't notice a bit of difference for sound or HP between the 2 set ups. Best thing to do for the exhaust, delete the DPF, you will notice a change in exhaust sound and a lot of performance. Save the $600 in the DPF back exhaust and sink that money elsewhere in the truck.
ICON 7" stage 5 suspension lift, Fuel Hostage Wheels, 37" Open Country M/T, DPF delete, H&S Mini Max, Bushwhacker fender flares, Wet Okele seat covers
TrollH03 is offline
post #5 of 6 Old 11-12-2013, 09:40 PM
Clayton1985's Avatar
12" dual stacks.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #6 of 6 Old 11-15-2013, 02:13 PM
TxBoyJay's 08 KR250's Avatar
4in TBE is all you need, bigger only for looks though.
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
