methanol???
is there any risks/problems with methanol injection? is snow's stage two controlled by a switch? could i control it with an upfitter switch or do i have to drill and fit a new switch?
the only risk is if its mixed to heavy , dont want to go over 50% mixture , the kit has a power switch to cut it on, then boost controls when the pump comes on and how much it sprays
It will work to the upfitter switches......but your going to need to drill for the LED, the switch will arm the system, but the LED will tell you when it starts to spray
whats the most cost efficient kit?
It all depends......same of the kits are rated and based on HP......I went with stage 2 instead of stage 3 because I just wanted something simple.......stage 2 runs off boost where as stage 3 has a LED monitor and runs off boost and EGTs, just more drilling, wiring, and work for the same result IMO
i know i want methanol but im not completely sold yet. what are the hp gains and how much lower are the egt's? which company is the best to deal with?
I did it more for the lower EGT's.....Snow performance claims 70HP with the 50/50 mix and the biggest nozzles. You can feel it in the seat of your pants, thats for sure. As for the EGT's I see at least a 350F drop at WOT and the pump is at full power
whats your mix and are they the biggest nozzles? if it is 70 horse on top of the 250 is it safe for the trans or would it be something else i need to look into?
I've been using the 50/50 mix, but I only use it at WOT when I'm racing or haulin a heavy load. The truck doesn't get hot quick enough to use the meth for passing or getting on the highway.......I doubt its 70HP, but never the less like NOS, if you use it smartly you'll be fine
