exhaust or spartan first - Ford Powerstroke Diesel Forum
Old 08-02-2008, 07:23 AM
i'am interested in getting the spartan programmer. can or should I put the progam in then drive and get exhaust done or get exhaust then the programmer. my fist diesel didn't want to mess anything up.
Old 08-02-2008, 08:58 AM
I would go with the Spartan first, and a DPF delete pipe. , then the the S&B, AFE, or some other intake system, and then the exhaust. It's really up to you...
Old 08-02-2008, 10:06 AM
this may sound crazy but,how hard is it to remove the hangers for the exhaust. i dont want to start a job until i know i can fnish. i want to do the dpf delete with xtreme sct. do you grind the hanger off the pipe,(any other way) does the hanger just slide out?looks like 1 of those deals were it slides in but not out
Old 08-02-2008, 10:33 AM
I think you should do the exhaust first, Get the truck to breathe easier first, then the programmer will be more effective. Just my opinion.
Old 08-02-2008, 11:44 AM
I didn't know if I could change the exhaust and put the delete pipe in and drive it from the muffler shop to home and it run without installing the spartan. don't want to be stranded if everything doesn't work.
Old 08-02-2008, 11:50 AM
In answer to that question, YES you have to have the programmer to put the DPF delete pipe on. Wont work without it.
You must get both at the same time.
Old 08-02-2008, 12:11 PM
so is it possible to put the spartan program in then get the exhaust installed. can get it installed cheaper than I can put it on my self.
Old 08-03-2008, 08:11 AM
AGREED 100%! I was in the same situation, but i ended up buying the spartan Phalanx and my dpf delete pipe and it was the best choice i could have made. The power and mpg is awesome. Now im going to buy my intake and exhaust here in the near future.
Not to mention i love the look on the peoples faces as i pull up to them in what seems to be a completely "stock" truck and then dump out some black smoke like thres no tomorrow as im pulling farther and farther away from them... ahahah
Old 08-03-2008, 08:34 AM
I think you should be fine for a short drive with dpf on and delete tuning, then again you could pry install the tuning as the exhaust is being installed...
Old 08-03-2008, 10:07 AM
I loaded the tune, drove a couple miles then installed the pipe. I used some copper antisieze on the probes, just in case.
