Can I install a dpf delete kit myself? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 11-02-2013, 11:10 PM Thread Starter
Sorry if this topic has come up, I'm new to the powerstroke world and this site. I seem to get lost in all the threads that never seem to fulfill my questions.
I just bought my first powerstroke, a 2008 f350 lariat. Regarding the dpf delete, can I do this myself? I have a buddy who has his mechanic brother install everything on his 7.3, and swears up and down that I don't possess the required skills to install the programmer myself. So here are my questions:
1. Can I install the exhaust and programmer myself, I know how to turn a wrench.
2. Can I install an exhaust (I.e. Banks) without installing the programmer at the same time?
3. Can I install the programmer without installing the exhaust at the same time?
4. What is the best programmer for my money?
Thanks guys!
BadCompany3905 is offline
post #2 of 15 Old 11-03-2013, 02:43 AM
Hands down SCT! That programmer seems to have the best results with custom tuning. (Stay away from canned tunes)
The biggest reason I went with that particular was because with a custom tune it also matches up your transmission shifting.
As far as a DPF delete, if you have the complete kit just read read read and have at her, it really does not seem to be that complicated.
Veemax is offline
post #3 of 15 Old 11-03-2013, 02:45 AM
And yes you can install the programmer first.
Veemax is offline
post #4 of 15 Old 11-03-2013, 03:30 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
It's hard to say if you can personally install your exhaust and programmer yourself. Some people aren't capable of changing there own oil (not saying you can't) so it's hard to tell what your skill level is. But I'd say an exhaust and intake is pretty straight forward and probably a 3 out of 10... Add dual exhaust and that goes up a little but still plenty do-able for the average joe. Programmers are extremely easy as long as you can follow the simple step by step procedure on the programmer itself. Do NOT install a dpf delete without using the proper programmer (make sure the tune you load is dpf delete compatible) otherwise the truck will constantly be in regen mode and that causes all kinds of problems. Good luck and keep us posted on what you decide... Also, and post some pics of your new truck!
dociceit likes this.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 15 Old 11-03-2013, 08:18 AM
bentstroke_02's Avatar
Keep doing your research on here before you buy anything. You can install your own exhaust/tuner. IF it was me and I had to do it all over again I would go with SCT tuner with innovation or gear head tunes. The exhaust I would still do flo-pro or diamond eye
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #6 of 15 Old 11-04-2013, 05:09 AM Thread Starter
Thanks for input guys.
Now when you say "canned tunes", I'm assuming that you mean preset settings?
I've been looking at the flo pro systems, they seem to have what I want for a reasonable price. As well as the sct livewire ts, the one made for the dpf delete.
Should I also do a egr cooler delete as well?
post #7 of 15 Old 11-04-2013, 05:33 AM Thread Starter
And thanks for the welcome btw!
post #8 of 15 Old 11-04-2013, 06:58 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Also remember innovative and gearhead can tune on the minimaxx. I recommend the minimaxx. Also yes if you have the money delete the egr coolers. Also
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #9 of 15 Old 11-04-2013, 07:25 AM
WoodBoy's Avatar
Never seen anyone running IDP on their minimaxx
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #10 of 15 Old 11-04-2013, 07:49 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Eric's tunes
08 F350 cc/sb 4X4
Tags
dpf delete
