methanol injection? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-27-2008, 07:43 PM Thread Starter
methanol injection?
Instead of us boost juice can't you use wind shield wiper fluid with no de-icer?
jcohvac1 is offline
post #2 of 14 Old 07-27-2008, 08:01 PM
KeepinItFord's Avatar
Heres a Bump.
I would also like to know
KeepinItFord is offline
post #3 of 14 Old 07-27-2008, 08:03 PM
doubledrop's Avatar
pretty sure I have seen reference to people buying the walmart brand of windshield washer fluid, etc. Even mixing it. will be good to know for sure, pricing out some kits myself.
__________________________________________________ ______________________________
doubledrop is offline
post #4 of 14 Old 07-27-2008, 09:23 PM
Project Abused
Goolsbymd's Avatar
Yes you can, make sure its a winter mix with meth. other wise its just windshield washer fluid in your cac tubes etc. I stick with the boost juice cause I know it works and is a good mix, even though I throw in some xtra water anyways.
TOTALED
08 Super Cab F250 4x4:
Performance: No Cat/DPF, Spartan 275, MBRP, aFe, Snow Performance, NX, Farmboy Fab, Spearco, SunCoast, Autometer, Mag-Hytec, Fox Shocks, CCV Mod
Looks: Rize Quad Link & Steering Stabalizer, KMC, Nitto Terra, Herculined Rocker Panels, AVIC Z2
For sale
96 12V Reg. cab Long bed auto, BHAF, CFM, KDP killed, 0 plate, DDP4, HTT 64/71/14, ATS Exh. Manifold. Waiting to install 7" mitre single stack 60# springs 4kGSK.
Goolsbymd is offline
post #5 of 14 Old 07-28-2008, 05:27 AM
boostd6.4's Avatar
Or get a drum of 99.99% methanol and cut it 50 / 50 by weight. It is cheaper to blend it yourself!
Mike
08 F-350 CC DUALLY LARIAT
6.4 LITER DIESEL
Soon for sale, all stock.
boostd6.4 is offline
post #6 of 14 Old 07-28-2008, 05:51 AM
Patrick's Avatar
You can run straight water, a methanol water mix, washer fluid (with no cleaners...Rain-X), or boost juice.
Legendary
Patrick is offline
post #7 of 14 Old 08-07-2008, 06:44 AM
i agree it's always better to stick w/ the proven stuff.
Kyle
1lowdiesel is offline
post #8 of 14 Old 08-07-2008, 07:16 AM
onebadf150's Avatar
from the mouth of matt @ snow in a bind you can take 1 gallon of blue -30 degrees windshield washer fluid to 1 or 2 pints i forget of HEET yellow container will give you a 50/50 mix meth to h20. I plan on running methanol and distilled water.
onebadf150 is offline
post #9 of 14 Old 08-07-2008, 10:28 AM
If you're going to use washer fluid you WANT the stuff with the de-icer. The de-icer IS methanol.
Also, one of the HEETs is pure methanol. I can't remember which is which (red or yellow) but one is isopropyl alcohol...the one that says iso-heet, and the other is methanol.
po-po 5.0 is offline
post #10 of 14 Old 08-07-2008, 12:38 PM
boostd6.4's Avatar
The Yellow is the Methanol. Expensive tho....
Mike
6.4 LITER DIESEL
