could oil overfill dtc code be related to sct
im getting an engine oil over fill message. i read a bunch of threads about it and am wondering if any of the fuel leaking isues could be from increased rail pressure causing it to leak into crank case. any ideas or opinions
I would check your oil level ASAP. Are you smelling any fuel in the oil?
Wasn't aware of any code for such at the time, but what was the number of the code? |
p2263 was the code, i read some threads on here about oil overfill codes and also some turbo underboost codes being the p2263. i had a CAI and took it off could the engine be used to more air and now im starving it. its only gotten the code since i put the stock air filter on. I went and got the oil changed today and it was only alittle over 15quarts they drained out of it. no diesel smell.
That is a turbocharger boost performance trouble code; possibly related to either the new tune or the air intake.
