Why wastegate? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-28-2013, 09:57 AM Thread Starter
Why wastegate?
Just wondering what the benefits of putting an external wastegate would be, and If I should do it. I have an 08 f250, EGR delete, DPF delete, 5" straight pipe, and a 310 tune. And I'm only pushing 35-37psi of boost so I don't think I'd need one? And if not when would I need one?
ColtonH00 is offline
post #2 of 9 Old 10-28-2013, 10:12 AM
lildevil02's Avatar
IMO if you have plans to spray or upgrade to bigger turbos then you will need a wastegate. If not, all you need is a good tune. there is no reason why simple bolt on mods will require an additional gate...... if the tuning is correct.
lildevil02 is offline
post #3 of 9 Old 10-28-2013, 10:21 AM
Heavy_GD's Avatar
Quoted: 1324 Post(s)
Feedback Score: 3 reviews
other than sounding cool.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #4 of 9 Old 10-28-2013, 10:52 AM Thread Starter
Well I'm planning on either Doing a single s366 turbo, or a secondary s475. So I will be pushing more soon.
post #5 of 9 Old 10-28-2013, 05:04 PM
WoodBoy's Avatar
I would wait till you did the single then
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 9 Old 11-05-2013, 02:23 PM
passatdiesel's Avatar
Bad backpressure sensor on the turbo's could cause an overboost senario.
2008 KR CCLB dually 6.4 4.10's Deleted w/6.0 manifolds & custom uppipes w/wastegate. TBTC, 67Gal tank w/ Fass 150.
passatdiesel is offline
post #7 of 9 Old 11-05-2013, 07:09 PM
WoodBoy's Avatar
I didn't pay attention to his boost numbers. What are your egts? Have you checked for leaks? That's a little low IMO for the 310
WoodBoy is offline
post #8 of 9 Old 11-07-2013, 04:12 PM
Your truck is pushing more than 35-37 pounds of boost.
Mine pushes just under 50 with a similar set up.
Nic - 2008 6.4L F-250 Lariat CrewCab 4x4
S&B Cold Air Intake, Spartan Tuned, DPF/CAT Delete, MBRP CAC Pipe.
WeatherTech Floor-Mats, Westin BedRails, Tinted Windows & Windshield, Weather Tech In-Channel Rain Visors, DDM 55W 8000K HID High's/Low's, DDM 35W 6000K HID Fogs, Smoked LED Recon Cab & Mirror Lights, LED Interior & Reverse & Third Brake Lights, 4" Lift, 22's on 35's, Top Gun Customz Traction Bars.
beachn is offline
post #9 of 9 Old 11-07-2013, 05:49 PM
I was going to say the same thing..I have hit 44psi on the 210 tune....
MobyS is offline
Tags
boost , diesel , external , powerstroke , wastegate
