250HP Sand Drag Race Videos
Well I figured it was time to put the 250 tune to the test and I entered into the El Paso Sand Drags this past weekend.........I entered in the Stock Modified class because I had a stock frame, stock drivetrain, stock motor with bolt ons......but I was a "diesel" and my reply was that I was close to 9000lbs and I was running against built 302 70's bronco that were a 1/4 of my wieght...... Well you only have to watch the first 40 seconds to see how I was going to level the field, but all the drivers in the class said it was unfair that I was running and I wasn't allowed to finish......but I thought I would share this with you guys so you know the 250 tune with stacks looks like.....also not only was I going to walk with the win, but the truck was shutting down in 3rd gear, so thats why the truck looks like I let off at the end..... Mike and I are already working on that, so the truck should run even faster.
YouTube - Sand Drags - Carill 1/4 de milla - MOD CLASS |
Truck looks Bad Azz!!!!
Looked like alot of fun..
I gotta get my hands on a first gen Bronco. Thats the only thing i have wanted more than a PSD |
Yeah there are hot down here......75% percent of the field in all classes, but Unlimited are usually Jeeps and early Broncos
PROPS bro, your truck looks kick a$$....!
Julian,
Sweet! What #'s did you run? Looks great with that single tire on the rear! Were you getting fuel cut? In 3rd? Mike |
.......they didn't have timing lights just lights at the start.......they just hand to guys at the end to see who won, which ended up being a huge ordeal in the higher HP classes, cuz they were so close.......yeah the truck cut out in 3rd because I would be spinning hard 1st through 2nd and when the truck would hit 3rd the tires would catch and the VSS would pick up a different speed and shock the truck, so it would shut down for a second and then come right back
Nice Video man, Looks likes a great time. I have always wondered what ya'll do out there in the desert
Sweet!!!!!
