Gauges with an xrt pro - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-27-2013, 07:27 PM Thread Starter
STEVEFX64's Avatar
I'm currently running my xrt pro on the Lower settings but have been thinking of taking the plunge and running the higher ones for even better fuel economy but have no egt gauge or boost over 40lbs. Is the insight from edge pretty much my only option or is it possible to get just a basic egt gauge on the pillar?
2010 F250 CCSB FX4 h&s XRT pro 300 4" sinister exhaust RCD EGR delete s&b dry intake 285/65/20 bfg at on factory 20"s tinted Windows undercover bed cover
STEVEFX64 is offline
post #2 of 11 Old 10-27-2013, 07:37 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 79 Post(s)
Feedback Score: 7 reviews
you can get an egt gauge from many a company. i have auto meter. glowshift is 50/50 and isspro is held pretty high.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #3 of 11 Old 10-27-2013, 10:07 PM
zdawg8394's Avatar
do the CTS, one of the best mods done to my truck. it seems to be reading accurately and the gauges are great/easy to read. but there is something about looking at an actual gauge. you can get 2 and three pod pillar mounts for these truck... maybe a 4.
08 F350 6.4 4x4 Lariat CCSB
-BDS 4 inch radius lift - Fox 2.0 shocks - XD monster 20x10 chrome rims - Toyo open country m/t 37/13.50/r20 - Procomp dual steering stabilizer w/fox stabilizers - 2wd valance - HID heads and fogs - escort 8500 x50 blendmounted - CTS insight with dash pod - interior led conversion
"When you nail the throttle in traffic trying to get around someone chr*st I think GM could have mailed me that 400hp faster then I got it out of the truck."
zdawg8394 is offline
post #4 of 11 Old 10-28-2013, 04:51 AM
muntu's Avatar
insight x 2
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #5 of 11 Old 10-28-2013, 11:12 AM Thread Starter
STEVEFX64's Avatar
does the insight pull its reading from the ecm on the truck or do you still have to drill and tap like in the past? i thought the truck had a factory installed egt probe before the turbo? so i didnt know if an analog gauge would work or if a insight was pretty much my only option to use the factory probe?
also how high of egt does the insight read? ive heard of over 15-1600 degrees egt with the hot damn tunes
post #6 of 11 Old 10-28-2013, 11:46 AM
Raul@Stealth Automotive's Avatar
you can do regular analog gauges or a CS/CTS.... i prefer the CTS.... i can get you a price on it if your interested...
Raul@Stealth Automotive is offline
post #7 of 11 Old 10-28-2013, 02:00 PM
pops250's Avatar
Just plugs into the obd port and set what you want to monitor.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #8 of 11 Old 10-29-2013, 05:03 PM Thread Starter
STEVEFX64's Avatar
so am i understanding this right that the edge pulls all of its readings from under the dash through the obd port? theres no drilling and tapping for it on a 6.4?
also with the old style pod gauges how would they draw thier readings would you have to wire in somehow?
post #9 of 11 Old 10-29-2013, 05:39 PM
BBBRRRRRTTTTT
Quoted: 79 Post(s)
You are Correct
post #10 of 11 Old 10-29-2013, 06:30 PM
yes the edge can view everything you need out of the obd 2 port... Analog gauges will have to be tapped in...
we can get you both styles
