Upgrading from 4” to 5” - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-18-2013, 01:09 PM Thread Starter
42Superman's Avatar
Looking at the Flo-Pro 5" Turbo Back No Muffler 08-10 Ford 6.4L EC-CC/SB-LB
Has anyone installed or running this kit? I have a 4” MBRP down pipe back kit now with no muffler. I want to upgrade to a turbo back 5” system. Is there a better kit for that?
Also is there much benefit?
Spartan Tuned -Running the 275HP
S&B Cold Air Intake
DPF Delete
4” MBRP Exhaust
10” Rize Lift with Traction Bars
Fabtech Dirt Logic 2.25 Dual Shocks Front & Rear
Fabtech Dirt Logic Dual Steering Stabilizer
Flo-Pro EGR Delete with Intake Elbow
Flo-Pro Intercooler pipe
CCV Mod
8000k HID’s High / Low and Fogs 55watt
20” x 12” Fuel Octane’s with 40” Toyo MT’s
42Superman is offline
post #2 of 12 Old 10-18-2013, 02:32 PM
Capt dong's Avatar
Quoted: 5 Post(s)
The I have the Flo Pro 5 inch turbo back kit. The downpipe is actually 4 inches and the rest 5 inches. Not loud. Flows good. Like it a lot.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 12 Old 10-18-2013, 02:43 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
I also have the 5" flopro with no muffler. Its not loud inside the cab, but it has a decent note outside when you get up and go. But not super loud by any means....the performance gains that ive read about arent enought to bother with the downpipe itself. Those are nto real numbers or anything and i didnt want to jack with it either.
Big_Smokey is offline
post #4 of 12 Old 10-18-2013, 07:36 PM
Clayton1985's Avatar
Just my opinion of course but Id think there is better things to spend the money on? Only thing ive heard is the sound is a tad different with 5" vs 4".
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #5 of 12 Old 10-18-2013, 07:54 PM
XPLOSIV's Avatar
Got mine DEI ceramic coated today. Installing it tomorrow. Yes, the DP is only 4". I definitely noticed better throttle response putting it on my 250.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #6 of 12 Old 10-18-2013, 07:57 PM
XPLOSIV's Avatar
IMO I'd just go with a new 4"DP since you already spent some $$$ on the MBRP.
08 F450 CCLB 4.30's
XPLOSIV is offline
post #7 of 12 Old 10-19-2013, 07:50 AM
WoodBoy's Avatar
My recommendation would be spend money on a quality downpipe such as powerstroker67's downpipe (streetdieselperformance). Are you wanting to swap to 5" for performance (which there aren't any) or just sound difference (very little)
The downpipe will be a performance gain and sound gain
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 12 Old 10-21-2013, 09:05 AM Thread Starter
42Superman's Avatar
I wanted to do something with the down pipe so I thought about just upgrading the whole system. I’m pleased with the sound it has now just thought it would allow the motor to breathe easier.
Is there really much performance improvement in just changing the down pipe? I’ve read that it doesn’t have the crimped areas like the stock one which would allow it to flow better.
S&B Cold Air Intake
DPF Delete
4” MBRP Exhaust
CCV Mod
post #9 of 12 Old 10-21-2013, 09:20 AM
rimshotwheelie's Avatar
I talked to Eric at Rudy's about this... he said leave the OEM DP there, there is no gain you will feel or really see. There is a small dent in it. Plus once you cut it out, there is no putting it back as you have to cut the OEM one out. He told me this and did not try to get me to buy it, even though I wanted to buy it. I ended up going 5" DP back Flo-Pro (not installed yet, on its way via UPS). Just my .2 cents. Great looking truck BTW.
rimshotwheelie is offline
post #10 of 12 Old 10-21-2013, 09:22 AM Thread Starter
42Superman's Avatar
Cool thanks for the info. I guess the next best thing is to do the gearing.
S&B Cold Air Intake
DPF Delete
4” MBRP Exhaust
CCV Mod
