sct tuner - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-07-2013, 10:11 AM Thread Starter
cbradley's Avatar
sct tuner
ok I got a question for you ? I bought a sct live on this forum well it was locked so i sent it in to sct got it back. Now it has innovative tunes on it but they are the 3.0 version and I guess my trucks computer has a newer flash cause they will not work. Can I get ford to put an old flash back in so the tuner will work? If not they want another $400 to retune the sct with the upbated tunes from idp.
cbradley is offline
post #2 of 9 Old 10-07-2013, 10:18 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 956 Post(s)
Feedback Score: 6 reviews
As far as I know Ford will only flash with the most recent file.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 9 Old 10-08-2013, 04:46 AM
WoodBoy's Avatar
Wow you got a bad deal there bud. Have you talked to Ted or anyone at IDP to see if they could get you flashed backwards?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 9 Old 10-08-2013, 06:22 AM Thread Starter
cbradley's Avatar
I have called Idp they acted like I had to buy new tunes . I am trying to update it though sct but that is not working either. I don't know
cbradley is offline
post #5 of 9 Old 10-08-2013, 07:32 AM
WoodBoy's Avatar
Yeah their update to the 3.03 does cost because of the New software and all they had to use for the new food flash
WoodBoy is offline
post #6 of 9 Old 10-08-2013, 08:28 AM Thread Starter
cbradley's Avatar
So I can't update the sct stuff or does Idp take all that off
cbradley is offline
post #7 of 9 Old 10-10-2013, 08:22 AM Thread Starter
cbradley's Avatar
ok finally got the tuner working . When it asks if the egr is deleted i put yes but I didn't delete it yet will that just turn it off or do I need to come back and change this setting ? It was a 9621or tuner I finally figured out
cbradley is offline
post #8 of 9 Old 10-10-2013, 08:27 AM
WoodBoy's Avatar
You done right. Always say yes to egr being deleted whether it is or not
WoodBoy is offline
post #9 of 9 Old 10-11-2013, 06:10 AM Thread Starter
cbradley's Avatar
i need to change this to my nightmare!!! So got the programmer in and working cut the dpf out cause someone had welded it all together put in my delete pipe and looked up under front driver wheel and there is a coolant leak. looks like the short little hose on egr cooler whatever it does is it usually just a hose or the whole egr cooler that is bad. it's leaking pretty good.
cbradley is offline
