Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Performance Parts Discussion
  #11 (permalink)
Old 07-03-2008, 04:47 PM
Pahrump Pahrump is offline
Thats right....when I first did my DPF delete I started it with the sensors plugged in...it started fine...but then I killed it and put everything together..and it would not start...I then cleared the codes.
Actually I set the truck back to stock, cleared the codes, then it started, then I tuned the truck again, and it was good.
  #12 (permalink)
Old 07-03-2008, 06:47 PM
Rocken1 Rocken1 is offline
I put the truck to stock cleared the codes and still nothing I wish I would of wrote the codes down to see what they were but didn't. There is still one code that keeps comming up a p1000 I called sct about it they say its just a flash code that means nothing it will go away when the truck runs for abit. have you read of any body having this much trouble? Do you think I should just order all the sensors in the exhaust and pray it starts. I just bummed
  #13 (permalink)
Old 07-03-2008, 07:33 PM
Powerage Powerage is offline
Why don't you put it back to stock and take it to the dealership. Let them fix it. Then put your pipe back on.
  #14 (permalink)
Old 07-04-2008, 06:16 AM
THats a good idea...set it to stock, put the pipe back on and call the tow truck form the dealer.
  #15 (permalink)
Old 07-05-2008, 07:15 AM
thats what i'll have to do thanks
  #16 (permalink)
Old 07-08-2008, 08:15 PM
returning back to stock. I was wondering when you return the truck back to stock with the sct 1.20 program can you go to stock on the programer or do you have to put the 1.18 program on, then go to stock on the programer to reset it?
  #17 (permalink)
Old 07-09-2008, 03:32 AM
powerstroker67 powerstroker67 is offline
Using the same version 1.20 just install the stock program. 1.18 is still a offroad DPF delete. 1.17 is the on road DPF on/regen on version.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
