oil cooler upgrades???? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-01-2013, 04:37 AM Thread Starter
CNYWhiteDually's Avatar
are their any out there that will drop temps considerably? where it is located at? is it the small cooler next to the intercooler?
CNYWhiteDually is offline
post #2 of 12 Old 10-01-2013, 06:06 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Check out the half kit from bullet proof diesel. Its an extra oil cooler that seems to work really well. I am hoping they come out with a system for the 6.4 that does away with the factory oil cooler like they have for the 6.0.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 12 Old 10-01-2013, 08:43 AM
Someone correct me if I am wrong, but I believe it is the one directly behind the intercooler. Should be wide and rectangular.
2008 F-250 FX4, Spartan Tuned, DPF/EGR delete, AFE CAI, 315/55/R20 Toyo Open Country
Intelocalypse is offline
post #4 of 12 Old 10-01-2013, 08:57 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That is not the oil cooler. The oil cooler is not external. You are probably thinking of the transmission cooler.
08 F350 cc/sb 4X4
post #5 of 12 Old 10-01-2013, 09:02 AM Thread Starter
im thinking about makeing an external one though is what im getting at.. where would be a good line to tap into
post #6 of 12 Old 10-01-2013, 01:14 PM
Just had mine replaced last week. After oil cooler, water pump, gaskets, and a new y pipe 2k! Now gotta get coolant filter. I wish somebody would of had a kit out. But I couldn't go any longer
Bubba8 is offline
post #7 of 12 Old 10-01-2013, 05:50 PM
I agree with you guys.
I think the bullet proof one is great BUT there has to some where to run hoses and then connect to a oil cooler.
Only place I see would be to splice into the turbo oil lines and run a line to a new cooler and then another filter and back to the turbo. Line seems small and I think it would only sample the oil ie like coolant filter. Of course I could be wrong. Nothing new there.
In other words my buddy at ford dealership said they can't look pass the bullet proof cooler but if it was more hidden like not replacing the oil filter housing they could look over it if my motor had problems.
GSchretter is offline
post #8 of 12 Old 10-02-2013, 06:07 PM
Capt dong's Avatar
Quoted: 5 Post(s)
i wouldnt mess with an oil feed line to the turbo. thats probably the last place to tap into.
08 F250 KR
08 F250 XL
Capt dong is offline
post #9 of 12 Old 10-02-2013, 06:28 PM
Agreed, just wish there was some where.
Return line can be dumped in the top side of the oil pan but where is a good source place. Hmm..
post #10 of 12 Old 10-03-2013, 06:17 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I personally wouldn't even mess with something like this. You have to make sure the oil pressure is not affected and that all the important parts are getting the oil they need. I am waiting until someone comes out with a kit that has done a lot of research and proves that it works well.
08 F350 cc/sb 4X4
