PMF traction bar questions - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-28-2013, 09:57 PM Thread Starter
superduty6.4's Avatar
Hey just looking for a little help. I have a set of pmf single bars. I'm finally getting around to installing them tomorrow morning but was just wondering how far I need to thread the joints into the bars themselves? The joints have about 3 1/2" of thread so I was thinking a little over half that distance on both the axle end as well as the front end? I'm just trying to get them into position and then tighten up the jam nut so I stays there. Then after I get the holes drilled in the frame for the front end I will loosing the jam nuts and make the final adjustment? Does it really even matter how far I thread the joints into the bars or is it just personal preference? Maybe I'm just over thinking it
Hopefully someone will have some insight. Thanks.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #2 of 18 Old 09-29-2013, 02:46 AM
montana6.0's Avatar
Its just for adjusting them half way would be fine that's what I did anyways and that's what Trevor told me. Not sure on axle ones though I didn't have those ones.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #3 of 18 Old 09-29-2013, 05:36 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
My instructions on my newton bars said to thread them 75% of the way in do you should only have 25% (roughly 3/4") That way you mount up the front mounts, then preload them and you should still have plenty of thread left in the bar for strength. Good luck and drilling through the frame sucked. Lol
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #4 of 18 Old 09-29-2013, 07:33 AM Thread Starter
Perfect, thanks for the info guys.
Yeah Travis hopefully the frame drilling goes ok. I've been reading that is kind of a crappy job.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 18 Old 09-29-2013, 07:46 AM
Drilling through the frame wasn't bad at all, i stepped it up twice before drilling the final hole, and use new drill bits on each side, dull pretty quick
Jimbo33 is offline
post #6 of 18 Old 09-29-2013, 07:57 AM Thread Starter
I just bought a new set yesterday in preparation.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #7 of 18 Old 09-29-2013, 07:58 AM
montana6.0's Avatar
Yeah had new drill bits for each side helped a lot.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
post #8 of 18 Old 09-29-2013, 07:59 AM
Quoted: 2 Post(s)
Yes- What Jimbo said. If you have to buy bits, don't fall for the all the High dollar, Carbide, Titanium, Diamond, Iridium Nuclear Powered drill bits. Order some good quality , inexpensive High Speed steel bits from a Place like McMaster Carr.
If you plan on keeping the bits for a while, then spending the money for Cobalt, makes sense, but again from an industrial supply. I have found after many years, that drill bits sold at Home Depot, Lowes, Etc are junk. All of them, doesn't matter if they are DeWalt, Ryobi, whatever.
Fordnut74 is offline
post #9 of 18 Old 09-29-2013, 08:00 AM
Let us know how it goes! I noticed a big difference afterwards, excellent investment
Jimbo33 is offline
post #10 of 18 Old 09-29-2013, 08:22 AM Thread Starter
I will definitely do that.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
