One Piece Driveshaft - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-28-2013, 01:23 PM Thread Starter
Powerstrokin_08's Avatar
Quoted: 5 Post(s)
I'm located just north of Houston around Magnolia and I'm wanting to get a one piece driveshaft made. I've got a little bit of vibration after my lift and I want to try it and see if it cures the problem. If anybody knows of any shops that could help me out the info would be great. Thanks in advance.
2013 King Ranch F-250 CCSB 6.7L 4x4
Carli 2.5" Leveling Kit
4" Rear blocks
Bilstein 5100's
AMP Research steps
Plain and Simple Custom Headlights
35" Toyo MT's on King Ranch rims
Fab Four Black Steel bumpers front and back
5" Flo Pro
No Limit EGR/Cooler Delete
Edge CTS2
PPEI EzLynk
*SOLD*2008 F-350 CCSB 6.4L 4x4
4" DP back
H&S Mini Max
Sinister EGR/Cooler Delete w/Intake Elbow
Carli 2.5 Pin Top Suspension
S&B CAI
NC Hornet CCV mod
20's&35's
Powerstrokin_08 is offline
post #2 of 18 Old 10-07-2013, 08:13 PM
How big of lift do you have? I did 3.5" and I've got a vibration that I can't get rid of also. Had the rear shaft balanced and played with the shimming etc and still can't elimate it. And mine isn't even that big of a lift either...frustrating. I've heard from calling around personally to local shops in SW MI that they can't make them strong enough for how long I need. The vibration is the only "bug" I've been trying to get rid of...
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #3 of 18 Old 10-07-2013, 08:29 PM
ZMANN's Avatar
Quoted: 1776 Post(s)
they are out there a few guys have had them made and really like them
Me I just used a PMF drop carrier setup
We Miss you Ronnie
ZMANN is offline
post #4 of 18 Old 10-07-2013, 08:42 PM
Do you have any info on that pmf?
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #5 of 18 Old 10-08-2013, 09:25 AM
44magnum's Avatar
Quoted: 2 Post(s)
Adjustable Center Carrier Bearing Drop Bracket
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #6 of 18 Old 10-08-2013, 09:34 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I have 5" lift (about 3 to 3-1/2" rear lift), I put 1" spacers under the carrier bearing mounts and that solved my vibration issues.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #7 of 18 Old 10-08-2013, 06:23 PM
I just started talking to Carolina driveline via email today. Seen them used in TV. See where that goes.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #8 of 18 Old 10-11-2013, 08:18 PM
Just an update on my conversation with Carolina driveline (which I heard about them on tv) and what they are working on for me at the time. It's a 4" chromoly steel mono tube for $425 without new flanges. However I've been thinking about just getting new flanges so I'll have a complete extra shaft laying in my garage for "just in case". I talked to them about if I needed a cv in the shaft. They have to get back with me about the cost for a shaft with new flanges. I emailed them back for a complex detailed list of what comes with the new shaft; wall thickness, type of u joints, how much shipping is, etc etc
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #9 of 18 Old 10-11-2013, 08:23 PM
I feel confident about the chromoly shaft being strong enough for 560 rwhp and 1000+ rwftlb truck because they make mono shafts for drag cars making 2500 hp after talking with them. They said they could make it overkill for my application, I said for this I'm 100% ok with that!
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #10 of 18 Old 10-11-2013, 08:53 PM
And he said they also balance the shaft to a 0-.003 runout
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
