Hatched piston, opinions wanted on build - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-28-2013, 08:54 AM Thread Starter
groove's Avatar
So, toasted #2 piston now pulling the cab so I can take it all apart and see how bad the cylinder is. Running my options right now and looking for advice.
1. replace bad piston, ARP studs and slap it back together if cylinder looks good
2. replace all pistons with HD ceramic slugs if cylinders are good
3. full rebuild, pistons, bearings ect if machine work is required
Question to you guys is how many have had a piston go south and have had only the bad one replaced?
My thoughts are to do them all, but my wallet is asking for second opinion
Cheers all
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #2 of 10 Old 09-28-2013, 11:23 AM
Talking
Right now, mine is sitting @ Rudy's diesel performance with a cracked piston with 105xxx on the odo. I feel that if one cracked and I just replace that one, I have seven other pistons with same wear and tear, so I would at least do all eight of them. On the other hand, he already has short blocks ready to go with a 3-year, unlimited mile warranty, so I'm thinking that is MY best option as I haul cars across the southeast US. Good luck with your decision whatever it may be.
2008 F450 KING RANCH
DELETED
H&S MINI
ARP HEAD STUDS
RUDY'S HD UP PIPES
S&B CAI
ALRADCO RADIATOR
OEM PISTON W/HOLE FOR PAPER WEIGHT
5R110W WITH BILLET GOODIES AND AERMET SHAFT
4 CAR WEDGE TRAILER
ALL WORK DONE BY RUDY'S
87K599 is offline
post #3 of 10 Old 09-28-2013, 12:15 PM
srjd's Avatar
Quoted: 2 Post(s)
Mines a 01/07 build as well. How many miles on yours. Do you get on it often.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 10 Old 09-28-2013, 08:26 PM Thread Starter
groove's Avatar
Only had the truck a week, knew it had issues when I bought it (Calgary).
I'm not hard on cars per say, but I want to know she can take the mini maxx hot tune all day long
Has 258,000km, and I drover it 800km home with the toasted piston getting 18mpg (hand calc), but I did use 7 litres of oil..
Thinking a bad injector took out the piston, as #2 stuck open a time or two on start ups.
groove is offline
post #5 of 10 Old 09-28-2013, 09:28 PM
srjd's Avatar
Quoted: 2 Post(s)
That's right I remember talking to you. Wish I would have looked at it for ya. How do you know it stuck on start up did it throw a contribution code
srjd is offline
post #6 of 10 Old 09-29-2013, 10:57 AM Thread Starter
groove's Avatar
yup, contribution and misfire on #2 (not when I was looking at it but the next morning lol). pouring white smoke. restart and fine.
Funny thing was driving it was relatively fine, not miss, no knock, lots of power.
I knew the truck was going to need work, just not an engine! oh well, still better than forking out 70k for a new one.
groove is offline
post #7 of 10 Old 09-30-2013, 07:31 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Man groove you have had some bad luck. IMO I would replace all of them with HD or international pistons if money permits. Once the pistons are upgraded I haven't heard of anymore problems cracking them.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 10 Old 09-30-2013, 08:41 AM
WoodBoy's Avatar
If he drove it home with that piston like that I am sure international pistons are out the window since they only come in stock bore size correct? I would contact Aaron and the guys at Rudy's and see what they have to say. They also have great prices on parts and great customer service
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #9 of 10 Old 09-30-2013, 11:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I thought I read that international pistons could be had in .20 over bore but I am not sure on that. I would also look into the HD pistons from Rudy's.
08 F350 cc/sb 4X4
post #10 of 10 Old 09-30-2013, 02:32 PM Thread Starter
groove's Avatar
I may have a good line on International parts, so that's an option. Other than that looks like Rudys will be getting some business from me. Should have engine out next week, that will determine how far I need to go. Hopeful that the block and heads are good. Will keep you all posted and take some photos along the way.
groove is offline
