AFE Intake install help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-26-2013, 07:10 PM Thread Starter
tryan08's Avatar
Just purchased a used AFE Stage 2 MagnumFORCE AIS intake and was looking for some help on installing it. Any tips or advice would be greatly appreciated. Never put an intake on before so any help would be good. Thanks in advance for the help!
tryan08 is offline
post #2 of 3 Old 09-26-2013, 07:20 PM
StrokiNDieseL's Avatar
Loosen the band clamps on boots,ccv tube(modify this if you want at this time) & any connection. Remove filter, ply apart the boot/airbox. Then pull air box up & away from fender(if I remember correctly) b/c it's just push in grommets that hold airbox secure. Then just follow instruction on install paper & you should be all set.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #3 of 3 Old 09-27-2013, 04:05 PM
Something worthy of noting - I had to cut about 3/4 to an inch off my CCV hose to get it to connect to the intake tubing, otherwise it had too much of a kink in it.
Intelocalypse is offline
