less smoke on a mini max? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-26-2013, 10:35 AM Thread Starter
what tune is out there that makes less smoke? live in socal and like to run a mini max but don't want all that smoke.. even on 0 setting.. thanks for your help
415dad is offline
post #2 of 10 Old 09-26-2013, 03:30 PM
WoodBoy's Avatar
You can contact gearhead automotive
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 10 Old 09-27-2013, 06:03 AM
Quoted: 2 Post(s)
what he said.. Matt @ Gearhead has his tunes almost smoke free. i love mine.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #4 of 10 Old 09-27-2013, 07:18 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I think after the 71 goes on I will give gearhead a call!
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 10 Old 09-27-2013, 07:41 AM
Quoted: 48 Post(s)
if he's saying LBF on 0 is too much smoke, Matt's tunes aren't going to fix his problem.
6.4's are dirty. I run Matt's tunes on both of my trucks, but they are not 100% smoke free by any stretch
drunk on diesel is offline
post #6 of 10 Old 09-27-2013, 08:43 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am hoping 6.0 manifolds, a ported intake manifold and a 71mm lp turbo will make my truck smoke free.
08 F350 cc/sb 4X4
post #7 of 10 Old 09-27-2013, 09:16 AM
WoodBoy's Avatar
6.4s are actually pretty clean in my opinion. Of course the race tunes are not going to be smoke free. My truck runs pretty dang clean on all of my tunes except IDP race and gearhead race.
Low boost fueling is only what it says, controls fueling at low boost. Not going to do much after boost comes up.
Maybe the OP should give a little more info on when he is having smoke problems. WOT? Just taking off normally at a redlight? Cruising?
Also, what are your modifications to your truck OP besides the programmer? Full Exhaust? Intake? etc
WoodBoy is offline
post #8 of 10 Old 09-27-2013, 09:50 AM
Quoted: 48 Post(s)
running the easy tunes with LBF on 0, you'll still get visible smoke... a 6.0 or an older 5.9 cummins can be 100% smoke free. I've never seen a smoke free 6.4 that didn't have the DPF in place
post #9 of 10 Old 09-27-2013, 10:29 AM Thread Starter
smoke
I have a 08 with banks intake and 4 inch exhaust, don't mind the smoke at WOT but its just from a light or just passing someone on the street. just not need problems pissing someone off..
415dad is offline
post #10 of 10 Old 09-28-2013, 04:55 AM
floorboy's Avatar
A minimaxx can be as clean or as dirty as you let it be. If your getting smoke at lights or passing people you may need to adjust the way you're driving. I can get a big puff at a light or go almost totally clean just by easing into it a little. Passing people, the same thing. There is more than enough power there that most of it is unneeded.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
