Full EGR Delete.. Oil Stays amber? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-24-2013, 12:27 PM Thread Starter
2010KR350's Avatar
It may be to soon to speak; I have about 200 miles on my oil change since the full EGR delete and now my oil stays amber. Prior to the delete it would turn black in 1 drive. It makes since to me why it is staying clean as the cylinders are not getting covered in soot and resulting to black oil but I did not think it would be that dramatic. I thought common rails always turned there oil black ( old cummins did at least.
Anyone notice this?
2010 F350 CCLB King Ranch. Mini Maxx Race - CAC Pipe - DPF MIA - Sinister Coolant Filter - Sinister EGR Delete - No Limit Intake - Custom CCV mod using stock parts - Devils Own W/M
13.01 @ 103
2010KR350 is offline
post #2 of 9 Old 09-24-2013, 01:32 PM
WoodBoy's Avatar
My oil isn't much darker when it comes out than when it goes in. It isn't ever black. Once it ever turns black, it usually always will be black from then on due to left over oil in the block when changing mixing with the new oil
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 9 Old 09-25-2013, 06:52 AM
Combs19's Avatar
Anyone notice this?
Is this true for anyone else. If so I'm thinking I need to do this sooner then I think. I would be a good reason to give to my wife to buy the kit.
2008 F350 Crew Cab Harley Davidson
Early 99 (converted to Late 99) Sold!!!
F250 Crew Cab short box
Mods: S&B Intake, H&S Tuner, Delete Pipe, Newton 2 1/2" Leveling Kit with 5.5" traction bar blocks, 305/60R20 Goodyear Silent Armor Tires on Stock Harley Rims.
Combs19 is offline
post #4 of 9 Old 09-25-2013, 08:29 AM
WoodBoy's Avatar
I forgot to state that I did my egr delete around 30k. I did my dpf and programmer around 1k miles. And my oil has always stayed clean looking, didn't change with the egr delete. I cant see how that would even make a difference in the oil color. The egrs only cycle coolant, and the soot that travels through them is burnt out in the cylinder. If enough amount of soot was able to get by and cause your oil to turn then you would have cylinder/ring problems and that wouldn't be your only side effect
WoodBoy is offline
post #5 of 9 Old 09-25-2013, 09:17 AM Thread Starter
2010KR350's Avatar
I just know that is why it was black in a cummins because the rings pull the oil down the cyliner walls like a window cleaner and the oil is soot filled.
13.01 @ 103
post #6 of 9 Old 09-25-2013, 10:06 AM
Combs19's Avatar
My truck has 34,000 miles on it now and has been tuned since 2,500 miles but no full egr delete yet and my oil is always black shortly after changing the oil. I also always change the oil every 5,000 miles and have run synthetic oil every time. I never beat on it and rarely pull a trailer even. I alway thought that the oil turning black was normal or at least it was in my last couple of diesel trucks. If I'm way off on this can someone please educate me? I hope nothing is wrong with my engine.
Combs19 is offline
post #7 of 9 Old 09-25-2013, 10:09 AM
WoodBoy's Avatar
It turning black is normal
WoodBoy is offline
post #8 of 9 Old 09-25-2013, 12:16 PM Thread Starter
2010KR350's Avatar
No worries on black. This is my first diesel out of 4 that has ever been non-black for over 30 miles lol. This whole thread was to see if anyone else has seen this.
13.01 @ 103
post #9 of 9 Old 10-06-2013, 12:51 PM
I have a full EGR delete, CCV mod and an FS-2500 bypass oil filter. And the dang oil is still black shortly after changing.
Antonm is offline
