Originally Posted by buckslayr
I got my pipe today, put it on, went on super easy[course I only had 975 mi. on it.]It looks to me like you have a 3.5 in the DOC and a 3.5 out the DPF.I would think the only reason for the DOC and DFP to be bigger is to trap more soot.really can't see how it gives you any more air flow to have a tapered pipe from the DOC to the muffler when it is squeezed down to 3.5 be fore the muffler anyway.I think I'll have to go with Spartan boys tests on this on this one
The diesel aftermarket performance business was built from the foundation of smoothing out flow. That's what it's all about. Mandrel bent exhaust pipes, intercooler hoses/tubes, mandrel bent down pipes and everything else to smooth out the flow to deal with the extreme EGTs a tuner produces. $1,000s and $1,000s of dollars in preperation are spent annually on smooth induction/exhaust hardware that doesn't make one single ponie, but allows those big 'tuner" ponies to run hard by substantially decreasing excessive engine killing EGTs.
That's how you build safe performance systems. Mandrel bent pipes are especially important in the exhaust area because rough corners or flattened down pipes disrupt air flow and cause major hot spots that cause EGT gains, which is enemy No. 1 in the tuner business..
Now, here comes "you know who" proudly endorsing these new dyno proven DPF pipes that have a 3 1/2" flat wall for hot gasses to directly slam into, directly out of a 1,200+ degree producing DOC I might add. . Now, it's OK because this tuner company says so, and because their dyno says so. Everybody and everything the diesel performance parts business was built on over the last 30 years is now tossed out the window because they say so?
I can't speak for everybody, but I get a little tweaked when my intelligence is insulted like that. Maybe they do believe what they say, and that's frightening....
I can understand that design, I truly can. I does the job, it's cheap and quick to make, it's light and easily packaged to ship and there is a lot profit left over, all good business, but don't endorse it as something dyno tested and leave out the other half of the story.
SCT sells the same junk.
P.T. Barnum's words still ring true everyday..
This picture demonstrates the amount of blocked flow your DOC back system will deal with. The 7 bolt flange is the actual size of the DOC exit pipe size.
I bet Gale Banks is peeing his pants laughing, and shaking his head wondering who could come up with a positive twist on this..
