6.0 Manifold - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-20-2013, 11:38 AM Thread Starter
bentstroke_02's Avatar
6.0 Manifold
Hey guys I have a few questions about a few things lol. My cab will be coming off the ol 6.4 next month for studs, push rods, and oil cooler. Well while I was in there I was thinking of doing a down pipe, up pipe, 6.0 manifold and maybe exhaust manifolds. Now im lost one what to get and what to do. Im sure there are all sorts of threads on similar subjects but I do have a life and work way to damn much haha. Now for the questions
1. what is the plus of a 6.0 manifold?
2. can I actually use the one I have sitting at the house?
3.What is the plus of a 6.0 exhaust manifolds?
4. What is the best up pipe out there and what is the plus of it?
5. I have flo-pro exhaust do I have to use a flo-pro down pipe?
Thanks ya'll
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #2 of 10 Old 09-20-2013, 11:44 AM
WoodBoy's Avatar
1. what is the plus of a 6.0 manifold? Better flow design and the 90 is built into the manifolds
2. can I actually use the one I have sitting at the house? yes
4. What is the best up pipe out there and what is the plus of it? You have to use 6.0 up pipes if you do the 6.0 manis
5. I have flo-pro exhaust do I have to use a flo-pro down pipe? No, you can use whatever. I would recommend a powerstroker67 downpipe. Rudy's carries them as well as Sean carries them himself at streetdieselperformance.com
Thanks ya'll
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 10 Old 09-20-2013, 11:49 AM
Term3's Avatar
I thought the 6.0 flowed worse then the 6.4?? Which is why some guys are making the 6.4 manifold fit the 6.0
Term3 is offline
post #4 of 10 Old 09-20-2013, 01:12 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The 6.0 manifolds outflow the 6.4 manifolds. There are pictures on the army showing the 6.4 manifold on the inside. It looks like it flows horribly. Also as woodboy stated the 90 is in the manifold and not the up pipe. Also the custom up pipes required for the 6.0 manifolds have heavy duty bellows. I am not sure if the up pipes will flow any more exhaust but you also can get rid of the egr crossover pipe.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 10 Old 09-20-2013, 01:13 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sorry just to clarify the 6.0 exhaust manifolds flow more than the 6.4 exhaust manifolds. The 6.4 intake manifold flows more than the 6.0 intake manifold. That is why the 6.4 intake manifold is being used on the 6.0. I hade Nate port my 6.4 intake manifold for me. Hope this clarifies
08 F350 cc/sb 4X4
post #6 of 10 Old 09-20-2013, 03:30 PM
Term3's Avatar
Ok that's what I thought.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 10 Old 09-22-2013, 05:48 PM Thread Starter
What should I do to the manifolds before I install them?
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
post #8 of 10 Old 09-23-2013, 06:02 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Possibly ceramic coating. I am unsure if I will do ceramic coating on mine.
08 F350 cc/sb 4X4
post #9 of 10 Old 09-24-2013, 09:11 AM Thread Starter
Okay guys I got some 6.0 manifolds for a whole whopping $50 haha. Now who builds the best up pipe? I have looked on elite and ruby's website and I am wonder if there is any where else to go?
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
post #10 of 10 Old 09-24-2013, 10:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Dark horse diesel
08 F350 cc/sb 4X4
