H&S XRT Pro Trans settings for Dyno run? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-20-2013, 05:09 AM Thread Starter
BlackSheep5's Avatar
Question H&S XRT Pro Trans settings for Dyno run?
I did a search and really didn't see anything about this question.
What settings should the trans be on for a dyno run when programming?
Or does it not matter?
I currently have it on SM2 with Med shift points.
Thanks.
BlackSheep5 is offline
post #2 of 3 Old 09-20-2013, 06:40 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
1:1 is where the measure takes place, and it really doesn't matter how you get there, so it's my position that it doesn't matter..
drewactual is offline
post #3 of 3 Old 09-20-2013, 08:14 AM
WoodBoy's Avatar
You want to run the earliest lock you can. And you dyno your truck in 5th. Get up to about 75-80 mph and roll into the throttle
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
