Carli Suspension - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-16-2013, 12:42 PM Thread Starter
shapiros's Avatar
Carli Suspension
In need of some advice. Just installed a Carli 2.5 inch Starter System/Leveling Kit. Truck ride MUCH MUCH better. However, I have a slight "shimmy" during takeoff (fast or slow). I have installed 2 degree shims to negate the rear lift and that helped. Should I keep shimming or is there alternate adjustments to the rearend/driveshaft that could be done? I'm positive it is the angle, just baffled that such a small change can make that much of a difference. Maybe the 3.31 gears make a difference...
Thanks
Sig
2010 F250 FX4 Sterling Grey CC SB 3.31 Gearing
  • 20" Pro Comp Wheels
  • 34" Nitto Terra Grapplers
  • Ionic step bars
  • Husky Liner mud guards
  • ReadyLift leveling kit
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
  • H&S Mini Maxx Tuner
  • Flo-Pro DOC/DPF delete
  • AFE Stage 2 Pro 5r intake
  • HID Bi-Xenon 55W, 6000k temp headlights
  • Complete LED interior/exterior lighting including front switchbacks
  • Webasto 4300 sunroof
  • AmSoil (engine, trans transfer and diffs coming)
shapiros is offline
post #2 of 8 Old 09-16-2013, 01:01 PM
WoodBoy's Avatar
Check your u-joints
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 8 Old 09-16-2013, 04:36 PM Thread Starter
shapiros's Avatar
Thanks for the reply but have gone through everything obvious. U-joints were top of the list. No problem there...
  • Ionic step bars
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
shapiros is offline
post #4 of 8 Old 09-17-2013, 07:46 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Just replied in your other thread, you're going to want to do a small spacer on your drive-shaft carrier bearing. That is what causes 99% of take of shudders.
OCVeloMan is offline
post #5 of 8 Old 09-17-2013, 09:25 AM Thread Starter
shapiros's Avatar
Driveshaft carrier bearing? Can you give me more specifics? Also, how does it need to be spaced?
Maybe on to something. THANKS!
Sig
  • Ionic step bars
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
shapiros is offline
post #6 of 8 Old 09-17-2013, 09:31 AM
DunesRunner08's Avatar
This is partially correct... if you space the carrier bearing, you are gonna want to remove the rear shims as it will be too drastic of a difference...
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #7 of 8 Old 09-17-2013, 10:05 AM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Missed the part about the rear shims. That is also correct. you're going to want one or the other but the carrier bearing spacer is the correct way to do it as it shares the additional angle among all the u-joints rather than leaning the pinion angle up.
It's the bearing that holds the center junction of your two-piece drive-shaft in place. You need to remove the two bolts that hold the assembly to the bed cross-member and use longer bolts and spacers (google search carrier bearing drop f250) to reattach the support at a lower point to lessen the operation angle of the drive-shaft.
post #8 of 8 Old 09-17-2013, 10:53 AM Thread Starter
shapiros's Avatar
Got it! Know exactly what you are referring to. Many THANKS!!!
Sig
  • Ionic step bars
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
shapiros is offline
