Coolant Filter results - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-13-2013, 06:06 PM Thread Starter
tony97gt's Avatar
Added a coolant filter about 5k miles ago. Pulled off the first filter and changed it out. If you're wondering whether it works, I'll let you be the judge. You can see the bits of sand and dirt floating in the top of the filter. Some brown crap came out in the sink when I poured out the coolant, I'm guessing it's rust or something. You can see the sand/dirt piled up right in front of the drain.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #2 of 18 Old 09-13-2013, 07:37 PM
Clayton1985's Avatar
This is the first filter with 5k on it? Thats nasty **** in there man! I changed my first one after about 1000 km's but saw nothing. Ill leave this one on for a while (until I R+R rad and coolant swap)
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 18 Old 09-13-2013, 07:53 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Amazing how nasty the coolant systems can get, even on newer vehicles.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 18 Old 09-16-2013, 07:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Did you flush before adding the filter?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 18 Old 09-16-2013, 09:49 AM Thread Starter
tony97gt's Avatar
Filter
No, using filter to remove debris first then plan on flushing.
tony97gt is offline
post #6 of 18 Old 09-16-2013, 09:50 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That's a good idea. That's what I did also and it seemed to work well
08 F350 cc/sb 4X4
post #7 of 18 Old 09-16-2013, 12:42 PM
Same here, Im curious if mine will look like yours Tony..
1999 Corvette Cpe
post #8 of 18 Old 09-17-2013, 12:55 AM Thread Starter
tony97gt's Avatar
For your sake, I hope not.
tony97gt is offline
post #9 of 18 Old 09-17-2013, 10:50 AM
So you are saying the filter was almost plugged up with dirt and crap?
Or was trash/dirt floating in the first picture.
Sorry eyes not too good.
GSchretter is offline
post #10 of 18 Old 09-17-2013, 11:52 AM Thread Starter
tony97gt's Avatar
Wasn't plugged up, just had a lot of junk come out when I turned it upside down. Filter definitely works!
tony97gt is offline
