Up Pipes - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-13-2013, 10:26 AM Thread Starter
Up Pipes
Time has come to replace the up pipes. I have a leak in the passenger pipe at the flex. I have heard this is pretty common.
I want to make sure I don't have to do this again. I see that there are quite a few companies that make aftermarket up pipes. I plan on deleting the EGR at the same time so I would like an up pipe without the EGR crossover. What makes the RCD pipe so much more expensive than the Rudy's pipe? Only planning on doing EGR/DPF delete, exhaust, CAI, and tune.
Do I need to step up to the River City up pipes?
On the same subject; I am planning on lifting the cab to do this. Looking at head studs and gaskets while I am in there. Anything else I should do? Don't have a crazy budget so please keep that in mind.
Does the Batmowheel require tuning a Spartan or H&S can't provide? Is the Batmowheel a pretty easy mod with the cab off? Down pipe to complement the exhaust?
Just looking for overall advice. I have searched the threads and a lot of cab off builds are overkill for me. I am looking for a bullet proof 550 HP engine.
Rich
2008 Harley is offline
post #2 of 8 Old 09-13-2013, 01:43 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Also check out dark horse diesel for the up pipes. They make nice ones for a reasonable price. I also thought about doing a batmowheel. I decided to step up to a 71mm lp turbo. If you are interested in a batmowheel I have one that I would be willing to sale for a good price.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 8 Old 09-13-2013, 05:22 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
If you are going to do the EGR delete. I would recommend doing away with the drivers up pipe all together to not have to ever worry about that again. Heres what i did.Obviously its a different situation, but it gives you an idea of something different to do with the drivers side and the EBP sensor bung thats on the drivers side.
Big_Smokey is offline
post #4 of 8 Old 09-13-2013, 05:22 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
post #5 of 8 Old 09-13-2013, 05:42 PM
TD-5's Avatar
Quoted: 3 Post(s)
I'm planning a cab off this winter the same as you & have been looking at doing Exhaust manifolds & up pipes.
I believe the Rudys up pipes are stock material pipes that they rebuild with custom flexible bellows, where as the RCD up pipes are custom built from scratch from heavy wall 304 stainless steel.
There are a lot of choices out there for manifolds & up pipes,
I like the Steed speed manifolds but he is having some production difficulties & his manifolds for the 6.4 are all on back order. These also require custom built up pipes which are available thru Rudys or Elite. Very nice pieces but pricey.
RCD makes some really fine looking 304 stainless manifolds for the 6.4. These will accept stock up pipes or their previously mentioned 304 Stainless Up pipes. These go for about the same $$ as the Steed speed stuff.
There is a Stainless log style manifold for the 6.4 available thru Rudys, but I don't know who makes them or what up pipes fit. Rudy's also offers a ported & coated 6.4 manifold but I haven't seen many comments on these either.
I will have to take a look at the Dark horse stuff, thanks.
TD-5 is offline
post #6 of 8 Old 09-14-2013, 03:35 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
6.0 manifolds are also a good option and gets rid of the pipe 90 degree bend that has a tendency to blow out
post #7 of 8 Old 09-16-2013, 06:32 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ This in my opinion is the best option along with custom up pipes. You can find them cheap from the 6.0 guys. And they seem to flow better than 6.4 manifolds. This is the route I am going. There are plenty of high powered truck using 6.0 manifolds.
08 F350 cc/sb 4X4
post #8 of 8 Old 09-17-2013, 12:38 PM Thread Starter
Thanks for all of the info guys. Time to start looking for some 6.0 manifolds it seems.
