spartan tuner monitoring - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-11-2013, 10:54 AM Thread Starter
CNYWhiteDually's Avatar
what is everyone monitoring on ther dashdaq? egt, eot, ect?
CNYWhiteDually is offline
post #2 of 8 Old 09-11-2013, 12:23 PM
WoodBoy's Avatar
EGT, EOT, ECT, Trans Temp, Fuel Rail Pressure are what I would monitor
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 8 Old 09-11-2013, 12:42 PM
kevinah's Avatar
What is proper fuel rail pressure? Why is this to be watched?
kevinah is offline
post #4 of 8 Old 09-11-2013, 12:57 PM
WoodBoy's Avatar
Depending on the tune 5000ish psi at idle, 5700-5900 on the higher hp tunes like 275+. If you ever start having any kind of effects, it is right there to watch and see what your FRP is like. At WOT you want to see above 24,500 maintained
WoodBoy is offline
post #5 of 8 Old 09-11-2013, 06:58 PM
What he ^^^^said and Boost.
MobyS is offline
post #6 of 8 Old 09-12-2013, 07:07 AM
3brorce's Avatar
If you need two more could monitor TC slip and pulsewidth/duration I think is last one I monitored sometimes.
Anarchy Diesel Tuning
3brorce is offline
post #7 of 8 Old 09-13-2013, 07:02 PM
Clayton1985's Avatar
I think theres like 20 or something on the screen I have mine on.
Edit:
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #8 of 8 Old 09-13-2013, 07:10 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
im running the screen with the single dial gauge and the other parameters on the sides. the gauge is EGT, the rest are EOT, ECT, fuel rail pressure, boost, tranny temp, ad intake air temp.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
