Trying to understand EBP. - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-09-2013, 05:05 PM Thread Starter
I am doing a EGR delete tomorrow and would like someone to explain EBP. I will not be installing a waste gate because I run 210 and lower tunes, but I do tow heavy. Can someone explain to me what I should be looking for. I can monitor it on my Spartan but not sure what to look for.
Thanks
MobyS is offline
post #2 of 22 Old 09-09-2013, 05:09 PM
WoodBoy's Avatar
You want to try and stay away from above around 70psi + atmospheric pressure. So if you are at sea level like me, you want to try not to see backpressure above 84.7psi. But you have absolutely no worries especially on those tunes. I would monitor other things besides backpressure
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 22 Old 09-09-2013, 05:38 PM
StrokiNDieseL's Avatar
I just started monitoring EBP from reading up through threads & put together that EGT's & EBP are the killer when things raise too high(temps,psi)? Hesitant to also add EGR myself b/c you do seem to hear the need for waste/blow off(due to boost psi your pulling?) & others say its not needed... New to this diesel world but trying to study the hell outta what's all over this forum & learn how to take care of my unleashed beast. Sure wish my mini maxx recorded all info & not just what's on screen monitor, then again I'm learning...
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #4 of 22 Old 09-09-2013, 06:16 PM
WoodBoy's Avatar
EGT's are what make power. On quarter mile passes and pulls I wouldn't be too concerned about EGT's. On the other hand when towing or pulling up a grade for a mile or 3 then is the time to be concerned about sustained EGTs. Also, with the typical intake, tune, exhaust, a wastegate is not needed 90% of the time.
WoodBoy is offline
post #5 of 22 Old 09-09-2013, 08:09 PM Thread Starter
Crap I am really on the fence now.... I am supposed to do this delete tomorrow, but am concerned that I need my coolers to keep my EBP in check while towing.
MobyS is offline
post #6 of 22 Old 09-09-2013, 09:24 PM
srjd's Avatar
Quoted: 2 Post(s)
Be less concerned about ebp and more concerned what those coolers are doing to the life of your engine. Since deleted my oil stays clean on the dip stick for a couple thousand km. not to mention what it does mixed with CCV in your intake
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #7 of 22 Old 09-10-2013, 07:05 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I agree with the above. Be more concerned with what it does to your motor and the crap it makes in your intake. In a couple of weeks I will be pulling off my intake manifold. I will try and get pics of what it looks like. The CCV and egr were ran for about 60,000 miles.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 22 Old 09-10-2013, 01:32 PM
WoodBoy's Avatar
Who/Where are you getting this information to even be concerned about EBP????? Especially towing or with a small tune.
WoodBoy is offline
post #9 of 22 Old 09-10-2013, 01:40 PM
I did the EGR delete about a two years ago and I use my truck for nothing but heavy towing (43 foot long toyhauler). Running the Spartan 210 tow tune (monitoring EBP) and never had a concern even towing thru mountains. Trans temp has been my biggest problem actually.
Antonm is offline
post #10 of 22 Old 09-10-2013, 04:28 PM Thread Starter
My tranny also gets hot in the hills..What should i look for hen monitoring EBP??
The info I have been getting is just off of Ford diesel forums! Best place I think.
MobyS is offline
