Broken Lower Fuel Filter Drain Lever - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-04-2013, 06:18 AM Thread Starter
I religiously change both fuel filters every 10,000 miles and try to remember to drain fuel from lower fuel filter inbetween. Over the years I've owned my 08 F250 6.4 the plastic fuel drain lever has gotten progressively harder to move and yesterday the darn thing broke off at the base...fortunately in the closed position. The Dealer says 1 hour of labor and $190 part so that's not gonna work either.
I've been unable to locate the proper part to do the job myself so I'm asking the group here for help. There appears to be a small plate on the side of the filter housing with 3 torx type screws. I'm not sure if just the lever can be changed out of if the entire lower fuel filter housing has to be replaced?
I'm not a mechanic type but if its no harder than changing filters and bathing in diesel i'm up for the job!
Thanks in advance.
Randy in Florida
floridarandy is offline
post #2 of 7 Old 09-04-2013, 06:30 AM Thread Starter
Shoulda searched first. Answered my own question. Part is 8C3Z-9A214-B.
post #3 of 7 Old 09-04-2013, 06:40 AM
I pulled the whole lift pump off when I fixed mine. There will be a waxy buildup inside. If you're going to fix it right, just buy the entire manifold cover. This includes the drain valve. Then get yourself some plastic quick disconnects for the fuel lines. Unbolt the whole thing and pull it apart. Clean it well and put the new manifold cover on. It should be good for another 100k+ miles.
Expirobo is offline
post #4 of 7 Old 09-05-2013, 02:27 AM
muntu's Avatar
expirobo
asking a favor....could you give a nuts and bolts description on how to get the pump out....how many plastic quick connects...what size.. where to buy.. any cutting to do. are the pipes to the pump from tank and to engine steel........ would help me a lot.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #5 of 7 Old 09-05-2013, 04:19 AM
I'm talking about the pump underneath the driver door on the frame rail.
1. Shut off engine.
2. Get your SAE and METRIC socket set, throw a piece of cardboard or what have you down on the ground and crawl under.
3. Using the cheap Autozone/Oreillys/Etc fuel line quick disconnect tool, disconnect the four fuel line connections by sliding them around the fuel line and into the coupling. Push them in well to release the spring and pull the fuel line out. This may be easier on some than others. Be prepared to get a little bit of fuel on you. An empty tank is better than a full fuel tank for this job.
4. Locate the 3 nuts on the frame that hold the pump on. Loosen and remove the pump. Might take a bit of finesse to twist it out. Don't forget to remove the electrical connections before removing the pump.
Once the pump is out, there are three or four torque screws that hold the cover on. Remove that and fuel filter from the housing. It might be best to crack open the fuel filter cap before you pull the pump since they stick pretty good sometimes and can be hard to do while holding the pump in hand. Open the pump up and spray clean with carb cleaner and a rag. Use compressed air to flush out all final debris. Leave absolutely nothing, even a spec of dirt, inside to minimize contaminating the fuel system.
Install is reverse. After install is complete, cycle ignition key 10 times, each time waiting for the fuel pump to shut off. This will prime the system and remove the air bubbles.
Expirobo is offline
post #6 of 7 Old 09-06-2013, 03:08 AM
muntu's Avatar
thanks man...info really appreciated....darn...now i'm thinking airdog2 while I got it out!!.
muntu is offline
post #7 of 7 Old 09-06-2013, 06:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ airdog 2 is a good idea for the filtration and water separation.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
