09 6.4L F350 Code P0234 overboost pressure - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-03-2013, 01:51 AM Thread Starter
I have a SCT SF3 tuner, Cat/DPF delete. Started to get the error code P0234 overboost pressure. It seems to come in at around 32 PSI boost if it stays there for like 10 sec or so. SCT rep says i need to return to ford once i set it back to Stock tune , and have ford do a update to my P30 stratagy. Has anyone done this at their ford dealer?If so was there any problem in doing this? Thanks in advance for your reply.
tjh40 is offline
post #2 of 6 Old 09-03-2013, 07:19 AM
superduty6.4's Avatar
I was getting this code to after a deal visit. If my boost would stay above 33lbs for 5 or more seconds it would go into limp mode and the p0234 was the code I would get. At the time I was running an edge evolution and when I talked to edge they said to just update the tuner and the problem would go away. I updated and didn't experience it anymore. When I talked to the dealership they did not seem to be very helpful so I didn't want to take the truck in to them. It was after I got the 11b23 ford update when the overboost problem started.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 6 Old 09-03-2013, 05:14 PM Thread Starter
Thanks for the reply, the SCT tech that i spoke with said" FS0P30 is known to have over boost issues. I would recommend returning the truck to stock with your SCT device and have the strategy updated to a newer strategy from Ford which corrects the Over Boost problem you are running into." With that i guess i will try going into the dealership that i have been using, one of the guys that works at that dealership is the one who did my Mods, so hopelully i can get some help
tjh40 is offline
post #4 of 6 Old 09-03-2013, 05:22 PM
WoodBoy's Avatar
SCT is right. See, sct takes a lot of information from your stock file and incorporates it into the tuning file and the P30 flash that Ford came out with was even very problematic in stock trucks that towed and etc so they came out with another flash that wasn't so sensitive
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 6 Old 09-03-2013, 10:19 PM Thread Starter
thanks for the info, i will stop by the dealership and see what they are going to charge me for this update flash, and get it done.
tjh40 is offline
post #6 of 6 Old 10-09-2013, 09:47 PM Thread Starter
Had ford do the update to the new update, and the overboost is gone and truck is running excellent, thanks for all your reply's
tjh40 is offline
