EOT seems low... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-29-2013, 12:17 PM Thread Starter
matted2thefloor's Avatar
EOT seems low...
I finally got a chance to hook up my monitoring device and after a long run unloaded at approx 88-91 degrees ambient air temp, the EOT never eclipsed 94 degrees. Coolant temps stayed at 192-194, but rose to 198 in REGEN. Scanned for DTCs but were none. Am I missing something here or is this how it is? Just seems like there is NO way the EOT can be that low...
I got my Blackstone report back and all the levels are at or well below average with 196,000 miles...no fuel or coolant at all...so I know the motor is healthy.
08 F350 6.4 STOCK
Ideas???
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #2 of 6 Old 08-29-2013, 12:47 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
What device are you using? I have the Scan Gauge II and you have to manually enter a ton of digits to setup each monitoring point. Maybe you just mistyped something?
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #3 of 6 Old 08-29-2013, 01:36 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As stated above what moniter are you using? If you are using an sct I believe they read differently.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 6 Old 08-29-2013, 04:13 PM Thread Starter
Using an SCT TSX8900... Its locked but I just wanted it for the gauges. I got it cheaper than a SGII so I didn't care it was locked. Does it need to be updated maybe...or can it even be updated as its been discontinued?
I set the high limit at 230...
post #5 of 6 Old 08-29-2013, 06:40 PM
srjd's Avatar
Quoted: 2 Post(s)
Sct reads coolant in F and oil in C. I'm pretty sure.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 6 Old 08-30-2013, 09:40 AM Thread Starter
BINGO!! I was beginning to wonder this as soon as I posted yesterday, but just didn't go do the conversion... Why on earth would they do that?????
94C = 201.2F
92C = 197.6F
Looks like I need to lower my HIGH limit then!!!
Thanks for the help fellas!!! Now if I could just get my tuner dilemma ironed out so I can install my EGR delete and exhaust, I'd be doing great!!
