After studs - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-24-2013, 01:41 PM Thread Starter
Lancer250's Avatar
After studs
So my truck goes in next week for new head gaskets ans studs. I'm also doing down pipe and egr delete. I have a mini max and dpf delete. What can I expect after the studs? Can I safely run all the power the mini max can offer me? The truck is my daily driver and I just want to drive it normal and play some.
Is there anything else I need to do while cab is off? I know about the wires under the intake and injector o rings but what else?
Lancer250 is offline
post #2 of 16 Old 08-24-2013, 03:11 PM
If you're having the cab off (and have the cash), better up-pipes wouldn't be a bad idea. The stock ones are prone to failure.
Take a good look at the rockers and pushrods while you've got the heads off. I hear the rockers wear out fairly easily.
B. Adams is offline
post #3 of 16 Old 08-25-2013, 11:49 AM Thread Starter
Lancer250's Avatar
Up pipes
I just ordered HD up pipes from Rudy's. I will make sure they check rocker arms when it is apart.
post #4 of 16 Old 08-25-2013, 12:46 PM
SpDyDaVe's Avatar
You can run the highest tune until your transmission pops.
2008 F250 CCSB Lariat
Spartan 350, Extreme Studs, Elite Lifters, Smith Bros Pushrods, RCD (Oil Pan, Manifold, Up pipes w/EGR), 6.0 Manifolds, S&B CAI, 4" SS DP, 5" SS Exhaust, Sinister Coolant Filter, Mishimoto Intercooler & Rad, K&P Oil Filter, OUO (ALA'S, Traction Blocks, Short Gusset Bars, Pin Kit, Top Plate, Track Bar), ICON (2.0 Front, Rear, Dual Steering, Springs, TEI)
NRA Life Member
SpDyDaVe is offline
post #5 of 16 Old 08-25-2013, 02:35 PM Thread Starter
Lancer250's Avatar
Ok. But......
Right. But the engine will strong enought to handle it?
post #6 of 16 Old 08-25-2013, 05:31 PM
WoodBoy's Avatar
I along with hundreds of others run the highest tune everyday on factory head bolts with no problems. These motors are tough
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 16 Old 08-26-2013, 07:09 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If you have the funds maybe look into a ported intake manifold.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 16 Old 08-26-2013, 08:25 AM Thread Starter
Lancer250's Avatar
manifold
What would the ported manifold do for me?
post #9 of 16 Old 08-26-2013, 10:38 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
better airflow, cooler egt's, quicker spool up and possible a little more power.
08 F350 cc/sb 4X4
post #10 of 16 Old 08-26-2013, 11:25 AM
Just remember, the engine will take everything you throw at it ...until something breaks from the stress. Just like any race or high output engine, it will break if being pushed beyond it's design specs. Unless you go through the bottom end, fuel system, and valvetrain with upgraded components, I would be worried about running it at full steam all the time.
Who knows though...
Expirobo is offline
